-   -   Careless unhitcher (https://www.airforums.com/forums/f464/careless-unhitcher-178132.html)
cac 02-24-2018 10:25 AM
Careless unhitcher
I am an idiot with a 2016 Flying Cloud 26U. I unhitched everything else but FAILED to disconnect the power cord to my truck before pulling away. The trailer's power connector to the 7 pin plug on the truck was damaged when it pulled out: the small "hook" on the trailer side plug that locks the cord in snapped off. No amount or kind of tape can keep the plug snug on the 7 pin.
The result is no trailer brakes and no trailer lights.
Can the trailer side plug be replaced without replacing the whole cord? Can I order that part and have an Auto repair garage connect it? The nearest Airstream dealer is in Paso Robles, 166 miles and two mountain ranges away. : (
YippieKiYa 02-24-2018 10:33 AM
Sure it can. Any RV store, trailer or camping supply will have it. Maybe even a major uhaul store.
You can do it yourself, it’s fairly easy.
Bill M. 02-24-2018 10:37 AM
Yes, the plug on the trailer cord can be replaced. Walmart and Ace hardware both carry them. I have done mine twice. Once in a Walmart parking lot and once in a ACE hardware parking lot after accidents of one kind or another on the road.
You can probably order the Airstream plug from Outdoors Mart. That might get you the same one that is on it now. It might be better than the hardware store ones. Yes, most auto repair places should be able to do the exchange. If you do it yourself take some pictures and make a diagram of the wire color code and connections.
Mollysdad 02-24-2018 11:40 AM
Replace it yourself until you get home. A replacement won't be moulded and water tight. At home replace the plug and wire to the junction in the trailer (or make one).
Don't beat yourself up. We could all be in your shoes.
RFP 02-24-2018 11:55 AM
Originally Posted by Mollysdad (Post 2070014)
< snip > We could all be in your shoes.
And some of us were in "those shoes" even before he was! :lol:
SteveSueMac 02-24-2018 12:15 PM
Many of us have done stuff like this. I crushed my 7-pin cable by routing it incorrectly and it got crushed somehow in a tight turn. I've repaired it myself and believe me - if I can - ANYONE can. You can probably find a YouTube on it too. Still - if you're unsure about it - any RV place or probably even a U-Haul place could do it for you.
Now you've got a good story to tell. They pile up over the years and make for good campfire discussion [emoji3]
You'll see stories here of people who forgot to chock their wheels on a hill - now THAT's a rough and expensive lesson...
Hang in there.
Mollysdad 02-24-2018 12:31 PM
I don't know if this is helpful, but I bought a "safety pin" latch for the AS. After closing the coupler, I put the pin in and clasp the 7-pin cable through it. That way the trailer wiring harness is centered for turns, off the ground, and before I can open the coupler, I have to deal with the cable. Works for me.
Mollysdad 02-24-2018 12:37 PM
Reminds me of the ESPN golf camera man who pulled up in his golf cart, jumped out and watched his cart roll downhill into a lake with the camera still inside!
Hoagie 02-24-2018 01:04 PM
When we bought our first trailer (a Starcraft) 12 years ago it came with one of these and during the walk-through the tech specifically pointed out running the umbilical through this loop for the same two reasons you cited: Keeps the cable centered and off the ground, and you have to deal with the cable prior to unhitching. Sound advice then and now.
DBinSD 02-24-2018 01:04 PM
We have all been there in some form of WTH did I just do.
Fix yourself and be thankful it was not a major item.
Good luck!
Ted S. 02-24-2018 02:45 PM
I used to pump gas when I was a kid, I really enjoyed watching folks drive away with the hose still in the tank.
Hans627 02-24-2018 02:52 PM
One time I did just the opposite. I forgot to plug the umbilical cord into the truck. I drove about 100 miles on the interstate highway before I realized the trailer had no lights or brakes. Stupid move! Nothing happened as a result but I still have nightmares about that incident.
So I never move without having someone check my lights and I check the brakes.
If we live long enough we all get smart!
YippieKiYa 02-24-2018 06:11 PM
I really like that idea. We’ve all done something like this, and can learn from their (your) experience.
Bobbo 02-24-2018 09:05 PM
Back when I had a Class C motorhome, I drove away from a campsite with the 120v power cord still plugged in. Fecal material happens.
robert claus 02-24-2018 09:30 PM
If you can wire a plug on the end of an extension cord, you can probably do this. There should be some sort of set screw on the side of the socket somewhere which holds the connector face in place. You remove the set screw, push the cord and connector face out to the rear, then you'll see where the individual wires connect. I know, probably clear as mud, but if you look closely you'll see what I mean. The rest of the job should become obvious.
Daquenzer 02-24-2018 10:20 PM
Someone should come up with a master checklist for hitching and unhitching an AS and put it out there. I know I have just about done something similar. Most of the time stuff like this happens when it’s pouring rain and your just trying to stay dry and in a bit of a hurry. Makin a list and checkin’ it twice might not be such a bad thing.
Should be such you can put it on a smartphone though so when it is raining the paper doesn’t get wet.:)
xrvr 02-25-2018 06:01 AM
My wife and i would each walk around the whole rig before moving checking tires, hookups, mirrors, and lights.
WhereStream 02-25-2018 07:10 AM
Is there anyone who hasn’t done the same?
I sure have, with a boat and with the Airstream.
Mattirs 02-25-2018 07:21 AM
My wife and I double check each other every time. She preps the interior and I the exterior, then we swap she checks the exterior, I the interior. For a final check we do both together.
Most importantly do not allow yourself to be rushed or interrupted.
I used to work from someone else's list but the flow was not right for me, so I reordered it to my taste.
I discovered this as I was making sure the stabilizers were up when I stood up and smacked my head on an open window cutting myself. Windows closed moved further up the list.
Walk around at least three times.
J-Dog 02-25-2018 11:16 AM
One time I did just the opposite. I forgot to plug the umbilical cord into the truck. I drove about 100 miles on the interstate highway before I realized the trailer had no lights or brakes. .....
I have done the same. :lol:
