-   -   no biggie, just an inexpensive & good caulk/glue syringe (https://www.airforums.com/forums/f456/no-biggie-just-an-inexpensive-and-good-caulk-glue-syringe-174013.html)
Bob Blarney 10-17-2017 09:16 AM
Hi,
Here's an item I picked up at the Kroger supermarket. It's a turkey injector that has several features to recommend it. The barrel & plunger are made of polycarbonate, The needle & hub are standared stainless steel Luer-Lok fittings (medical style & grade). It can be fully disassembled for cleaning, including removing the luer fitting from the barrel. I would not soak in solvents, but a quick wipedown shouldn't hurt it. It might be a good idea to bore out the Luer fitting a bit. And all that for $2.50.
