-   Electronics & Connectivity (https://www.airforums.com/forums/f317/)
-   -   Ok I give up (https://www.airforums.com/forums/f317/ok-i-give-up-173820.html)
zapper 10-11-2017 07:07 PM
Ok I give up
I hate asking such a silly question, but on a 2017 30' FC where is the latch to drop down the bracket attached to the TV from the wall in the kitchen? I have looked between the TV set and the wall from the top, left side and bottom, nothing.
When I bought the FC the Tech unlatched the TV, it folds down from the top. So I know that it detaches, but cannot find the latch mechanism to do it again.
kendrick.l.j 10-11-2017 07:26 PM
Not a silly question. So much information is coming at you very fast during the orientation or walk through that it is very easy to forget how to do this or that.
I can’t answer your question because I don’t have your model or floor plan but I am sure someone will be posting shortly with the instructions.
uncle_bob 10-11-2017 07:50 PM
Hi
I also don't have a FC so the "rig" is likely a bit different. The latches generally have a cloth strap on them. If you can find the strap, you have 90% of the problem solved.
