Disc vs Drum Brakes?
I will be purchasing a New Safari SE 25SS in the next year and my question is, Do I want Drum or Disc Brakes?
Disk - no question about it! I had the Kodiak disk brake system installed on my 67 Caravel by the Airstream dealer in Weatherford, Tx. David Tidmore, the manager who is DTBW on this forum said that I wouldn't believe the difference and that was an understatement. I use the Prodigy brake controller and the the stopping is so controlled and precise you can't tell there is a trailer behind you. I'll never have another drum brake system after having this setup.
Disc!
Thrift,
You will NOT go wrong with the Kodiak disc brake package! The function of a trailer brake is to stop - I am yet to test a braking system with as good of results stopping as the Kodiak. My two cents.:blush: Regards, Henry |
Excuse my ignorance, but is the Kodiac Disc brake system a standard option from Airstream?
Yes!
Kodiak manufactures the disc brake system that will be used by Airstream. Visit www.kodiaktrailer.com for more information.:brows: Regards, Henry |
Disc without question
We had the 34-tripple axle converted to Kodiak disc a year ago. The Airstream now has more brake power that the Excursion! We have no fade when Decending from the mountains in Colorado. It priceless to have this feeling and control! :bb:
Did you substitute the dics brakes for the original drum brakes on your existing axle? Or did you buy a new axle with the disc brake set up installed on it? What axle are you running under your '67 Caravel, original or a replacement axle? Thanks for more details. |
disks versus drums
Hi All
Has anyone converted over to the 12" Kodiak disk brakes and used the Alcoa slotted mag wheels from the 70's? I have done the change, and am not finished with the plumbing yet but I ran into some clearance issues with the mags rubbing on the calipers. I tried some steel wheels I had and they have plenty of clearance. I was wondering if anyone else has run into this. I am really looking forward to having them finished and working. Thanks Mike B |
Wheels
Mike B,
I can't help with your issue however my 34' came from the factory with 15" American Racing wheels so fit had already been addressed. Over the years, I have had peridoic fit/clearance problems with cars, playing with tires sizes has backfired on me :blink: so anything with wheels would be fair game for a good fit. |
Wheels, wheels, wheels?!
This thread is developing quite nicely.
The Kodiak specifications for the “Airstream” style disc brakes (5200#-6000# capacity) specify a 15” or larger wheel will work. Mike’s wheels were 15” and he still had a slight rub. This to me shows that variations can exist amongst 15” wheels (different per wheel manufacturer). Like Mike, I am curious about the older Airstream style wheels as well. Regards, Henry |
Maybe there is a slight difference in the offset of the wheel hub. I know when I was ordering new wheels for the Caravel there were some choices of offset.
Vented Kodiaks
My Kodiaks disc are vented, are all Kodiaks vented?
I installed disc brakes on my 1963 Overlander, and the stock steel wheels from my 1971 Airstream fit fine, no rubbing. I am, however, running Dexter's disc brake setup, not Kodiak. I am not sure if the interference is the same Dexter vs. Kodiak.
I have no practical experience yet, since I have not towed the beast yet. Can't wait to give it a test, though. |
The Alcoa's have a half inch positive offset. If you look at the wheels they are massive as far as thickness is concerned, much more than most modern wheels that I have seen. Thanks for the feedback and like those that have already done the change I am looking forward to the increased braking that will be available. Thanks again Mike |
I think so!
To the best of my knowledge all of the Kodiak rotors, both integral and non-integral, are vented. Regards, Henry |
My two cents!
I do not know what Airstream would charge for the conversion on a new coach (non Classic). However I do know that Kodiak has a disc brake system available (as a retrofit) for almost any Airstream ever manufactured. These can be purchased as a kit to be installed by a dealer or a retail customer. I can tell you also that I have had many dealings with the folks at Kodiak and that they are top shelf. They offer many product offerings instead of a “one size fits all” approach. Quality is excellent. Availability has never been a problem. They also stand behind the product and offer excellent customer support. The only negative that could be pointed out is price. I feel that the price is in line but the cost of the conversion may have a bit of “shock value” to the average individual. However if you really look at the complete picture, over time, the price is not actually a negative. My two cents.:huh: Regards, Henry |
