-   Airstream Lifestyle (https://www.airforums.com/forums/f483/)
-   -   Kitchen storage and organization (https://www.airforums.com/forums/f483/kitchen-storage-and-organization-172657.html)
megan 09-12-2017 12:11 PM
We have a 75 Overlander and it doesn't have but a sliver of a pantry next to the refrigerator and that is where I keep all of our canned and dry goods. Above the countertop are two roller bins and I've been keeping dishes up there but they get jammed or crammed in and it's very disorganized. Where do you guys keep your dishes and pots and pans? I can keep pots and pans underneath the sink but that cabinet isn't the cleanest. It seems to always get Dusty from the tire wells.
4riveteers 09-15-2017 03:37 AM
6 Attachment(s)
We have a 2016 27' FC FB but maybe some of these ideas can help you out. We utilize small height areas for our dishes and glassware under our sink so no vertical space is wasted. Attachment 294862Attachment 294863Attachment 294864
We used a sock organizer for glassware. Camco Stack-a-Plate set for plates and bowls.
Confining small items into clear storage bins.
Attachment 294865
Vertical storage.
Attachment 294866
Stacked collapsible dish rack and dish pan under nested pots and pans. Felt "petals" between pots and pans to keep from rattling.
Attachment 294867
Hope you can use some of these ideas. Good luck!
Protagonist 09-15-2017 04:05 AM
If dust can get in from the wheelwells, find the cracks where dust gets in, and seal therm, either from inside or outside.
Or if that's too much trouble, wash the pots and pans before using them.
Or if that's too much trouble, wrap the pots and pans in clean, new trash bags turned inside out (so that when you turn them right-side out and use the trash bags for trash later, the dust is on the inside).
The point is, there are any number of ways to make it work, and storing heavy stuff low in the trailer instead of high is always good.
seastonemtn 09-22-2017 05:08 AM
I Love your felt petals!
Where did you get them?
4riveteers 09-25-2017 01:13 AM
Hi-thanks! I found them at Home Goods and TJ Maxx. Love a bargain! You can also get them on Amazon-different brands and configurations.
Good luck!
P.S. Some have petals that are wide. I love to use them for hot plates or for protecting counter from getting scratched up.
bobzdar 09-25-2017 09:50 AM
In our '67 we keep them in the overhead cabinets. As long as we stack like dishes together they seem to be fine and don't move around at all.
seastonemtn 09-26-2017 04:58 AM
Good luck!
I had thought of that! Lightweight trivets! Thanks so much Stacy. I'm on the hunt!
Chris
