-   -   Zip Dee Relax Awning Problem (https://www.airforums.com/forums/f442/zip-dee-relax-awning-problem-171912.html)
CEG 08-26-2017 08:05 AM
Good morning all,
I have a problem with the awning on my 2017 25FB closing properly. When the awning gets to within 8-12 inches of full closure it stops. I have to open it a few inches then close again, it then closes normally. Has anyone else experienced this issue? BTW, when I took it back to the dealer for this problem, the awning performed flawlessly!! :angry:
Thanks in advance .....
Chuck
uncle_bob 08-26-2017 08:08 AM
Hi
I've had mine do that once. It's run fine all the rest of the time.
MissingLink5 07-06-2018 05:14 PM
I was told by a GM at Airstream Adventures Nothtwest that you need maximum power (voltage) when you are opening or closing the auto awning. Make sure spouse is not running airconditioner, microwave, electric heater or another strong voltage pull appliance when you use the awning.
wulfraat 07-06-2018 06:13 PM
Mine does that too. I have a full lithium power system and always have a very healthy 13.2 - 13.5 volts supplied to the awning - so it is not a low power issue.
I believe the sensors get confused as to where they are in the process and send a signal to early to cut power when they think they the awning is fully closed.
As you've noted opening a bit then closing back again does the job / resets the sensors.
Stormalong 07-07-2018 08:44 AM
Same problem occasionally
We have the Relax power awning as well. We use it often, and have twice experienced the partial closure. Opened it slightly then resumed action to full closed position.
thewarden 07-07-2018 11:22 AM
I also have a sense this is related to power. I have had this happen on a couple of occasions when retracting the awning while on battery power, even though our batteries are fully charged. I have yet to ever have this happen when we are plugged in.
VaTravelers 07-28-2018 07:29 AM
It has happened to us since the trailer was new almost 2 years ago. Weíre going back to the factory next month for two year warranty visit. Itís on my list so Iíll let everyone know how they deal with it. I suspect itís a sensor adjustment. Other than that quirk it works fine.
Airhead2018 08-20-2018 05:19 AM
https://www.airforums.com/forums/f442...re-185765.html
