Water Leak
Hello,
This is my first post and am sad that it is over a problem with our new Safari 25'SS (2005). We first noticed a leak after my husband tested out the shower for the second time. The first test he took a cold shower, he forgot to turn the water heater on. He took the second shower in the morning and when I got home in the afternoon I noticed a leak coming from the piping that comes from the bottom of the trailer and I believe empties to the black tank. The area has calking and a black rubber piece around it. If you go into the shower you could draw a straight line from the faucet to this pipe. Also the water pump seems to have air in it, which I'm assuming is from the leak. I say this because when you run the water, the pump makes a jerking type noise rather than a fluid sound. Also when the pump is left on it periodically seems to turn on and off. We turned the pump off for 24 hours and then turned it back on and tested all the faucets and looked at all the piping that was easily accessible to see if there were any other obvious leaks or problems, and we did not see any. We did however notice that the original leak did not seem to begin again until we ran the hot water. The pump was still jerky when turning the water on. Our worry is that there may be a loose valve someplace we can't see and water may be leaking into the walls. Any help with this would be greatly appreciated. Thank You! |
