-   -   Water/Hot Water 2018 Classic (https://www.airforums.com/forums/f445/water-hot-water-2018-classic-170926.html)
paiceman 09-18-2017 05:56 AM
Great to hear. Sometimes learning about a particular RV, any RV, is like herding cats. It takes a while.
Enjoy
Bud
uncle_bob 09-18-2017 08:54 AM
Hi
Don't know if this has been posted recently. I ran into a gentleman at the Hershey show at the Alde booth there. We chatted a bit about things like getting to valves and seeing this and that. He offered up that Alde is quite willing to help people with their systems:
Alde Corp
Tel: 360-597-3017
Toll Free: 877-860-9814
info@alde.us
www.alde.us
They are in Vancouver, WA so calling at 8AM eastern time probably isn't going to work very well :)
mojoe7009 09-19-2017 07:36 AM
Originally Posted by uncle_bob (Post 2010079)
Hi
Alde Corp
Tel: 360-597-3017
info@alde.us
www.alde.us
It's too bad that Alde and Airstream are in complete denial that anyone can get a 10 minute hot shower on a 2017 Classic, even though there are several testimonies to that effect on this forum. For the cost of a plane ticket and a hotel room they could fly paiceman or one of the others to Ohio and demonstrate how it's done. Seems a cheap way to satisfy a whole bunch of their customers. Or they could spend thousands in warranty repairs that are probably just setup problems and continue to have multiple really p....d off customers. Kind of a simple choice to me, but then again I like simple. Does that make me stupid[emoji12]
paiceman 09-19-2017 07:52 AM
I no longer fly - BUT, they could pay my way and I'd be more than happy. But, I continue to believe it's a Lawyer imposed liability issue and therefore, they do not want to "know" that this system can be pushed and heated to 150F Plus and give two nice long hot showers.
So, folks who own one are more than welcome to read the Alde sections here, follow the directions and love their units or contact one of us who has successfully achieved such bliss.
Bud
james.mileur 09-19-2017 07:56 AM
Anybody ('18) out there with Alde bliss that has a working Alde Flow (continuous hot water), Alde Heat and Sanitary water (close to 10 mins above 90 in the shower), and a working Firefly/Alde interface?
uncle_bob 09-19-2017 01:18 PM
Hi
I did have a conversation about the upper temperature stuff with the gentleman. He confirmed that indeed there is an issue with telling people how to set up a hazardous situation. Very much the same conversation I've had with a number of plumbers over the years ....
paiceman 09-19-2017 03:35 PM
Originally Posted by uncle_bob (Post 2010596)
Hi
Not only will Airstream nor Alde tell people how to get the showers hot, but I believe most certainly will not actually do it either and I am further betting that if they get into a "modified" system they will set it back to factory specifications. Which is why unless mine totally fails, it does not go back for any work on the Alde nor the empty, purge and re-fill as recommended at two years.
Bud
uncle_bob 09-19-2017 03:45 PM
Bud
Hi
I've reset these sort of systems (hot water thermostats) on a lot of houses I've owned. I've never had a plumber reset any of them. I have on occasion re-set them to "safe" levels when selling the house. More or less it's "don't ask / don't tell".
ajwbarnard 09-22-2017 07:46 PM
We finally had the time to recalibrate the mixing valve. I think we have finally solved the hot water issue!!! We had 2 back to back showers. I, who like my showers hot, couldn't use it at the max hot water setting in the shower. (So no taking the anti-scald device out. That was the last step.) I filled up 25% of the gray water tank. My husband added another 20% with no decrease in temperature.
ajwbarnard 09-22-2017 07:51 PM
Still have to work on heat. Waiting for the Alde fluid from JC to have on hand just in case the level goes down too much on bleeding. We had stopped at dealer today to pick some up. They said, "What?" After the service mgr talked with the technician, he returned to say, "No we don't carry that." Still some communication issues between the Firefly and the Alde panel. The shower boost does not register on the Alde panel after turning it on at the Firefly. May need to wait for a software upgrade for that or some wire is crossed.
uncle_bob 09-23-2017 11:26 AM
Hi
One interesting thought about the mixing valve:
Is it impacted by water pressure? It's just a simple mechanical gizmo so maybe it is. I believe our campsite supply has a flow restrictor on it (or lazy Bob should check again for a kink in the hose ....). Something has the pressure changing here. That's got me wondering ....
paiceman 09-23-2017 03:37 PM
Originally Posted by uncle_bob (Post 2012240)
Hi
Our trailers have a pressure regulator in them. I have always used one on the campground water outlet. I did our first trip out and had very little pressure. Took off my pressure regulator and pressure was and has been fine.
Bud
uncle_bob 09-24-2017 07:40 AM
Bud
Hi
A pressure regulator helps with pressure that is to high. It isn't going to do much for the campground that seems to think 30 psi is a fine water pressure. I don't think we are down at 30 psi here, but it is sometimes below the 50 or 60 psi that the regulator should cut in at.
paiceman 09-24-2017 05:52 PM
Originally Posted by uncle_bob (Post 2012545)
Hi
I've run into few of those that use a well and pump and when a number of people are using water the pressure drops thru the floor. Our issue was having two pressure regulators, I think, as when I took the exterior one off water pressure was fine.
Bud
ajwbarnard 09-25-2017 04:39 AM
I am not using an external pressure regulator. The pressure at the spigot was in the 50 psi range, so I am just using the internal regulator. I have better pressure using the water pump and fresh water tank. Since the fresh water tank keeps filling up on its own, figure I should use it rather than waste it!
james.mileur 10-08-2017 03:06 PM
Any y'all 18 Classic Alde folks have a shuddering or rumbling while on gas while at altitude, especially on high gas, as indicated by higher blower rpm on the Alde service panel? Any 17-ers added an additional gas regulator to solve said vibrations?
paiceman 10-09-2017 05:41 AM
I've not been at an altitude using it higher than 4,000' and at that altitude had no issues, so I've done nothing.
Bud
uncle_bob 10-09-2017 08:49 AM
Hi
Let's see. I'm here and the shore of the Atlantic is over there .... does "about this much" count as altitude?
I don't think we have many campsites in the east that would let us check things above a few thousand feet. I'm guessing that "at altitude" is more in the vicinity of 8,000+
switz 10-09-2017 10:40 AM
Just wondering if the oriface for the Alde gas burner would need to be changed for the higher altitude to keep the fuel/air mixture relatively stable?
There are altitude specific orifaces for the Genconnex propane conversion for our two Honda 2,000 watt generators.
Captain Hank 10-09-2017 12:06 PM
I was in the Canadian Rockies this summer for over 3 weeks. Elevations 3500'-5000'. I did not experience the gas noise that others have reported. Does anyone know at what elevation this occurs?
I was at JC in July and asked about the High altitude mod. They said they were not doing it at this time. They said some dealers have done it, but no details. Does anyone have details on the mod?
