-   -   black water tank size needed (https://www.airforums.com/forums/f444/black-water-tank-size-needed-16780.html)
altastars 05-29-2005 02:52 PM
for my 71 safari. Does anyone have this info? Thanks
uwe 05-29-2005 03:56 PM
My 1971 Tradewind ( wet bath) had appr. 12-15gal capacity.
Just enough for 2 people using the toilet for 2-3 days.
overlander63 05-29-2005 07:38 PM
depending on which version you have:
Above floor- 10 gallons
Below floor- 15 gallons
Your capacity may be less, depending on how much solid, non-removable residue you have in the tank.
Dbraw 05-30-2005 06:29 AM
Our 71 Safari has a 14 gallon black water tank.
uwe 05-30-2005 09:03 AM
Our 71 Tradewind ( tank above floor) showed full at 12gal ( tank monitor), but could hold quite a bit more than that. Hence, my estimate of 12-15gal.
overlander63 05-30-2005 04:24 PM
Interesting. Our '72 had a ten gallon black tank above the floor, and the '75 has a 15 gallon above the floor. My service manual shows 80 pound black water capacity on above -floor models, and 120 pounds below floor, which at 8#/gallon, works out to about ten gallons and 15 gallons respectively. Of course, the best measure is to start pouring in one gallon jugs of water, till the tank is full, and you will have your answer for your particular coach.
