-   -   Upgrading to 2nd AC unit? (https://www.airforums.com/forums/f427/upgrading-to-2nd-ac-unit-164209.html)
LY007 03-21-2017 06:13 PM
My 83 Excella has one AC and 30 amp service. If I replaced the 12v bedroom fan vent with a new AC unit, I know I would have to replace the 30 amp mainbreaker with a fifty, add a new breaker circuit, and replace the 30 amp shore power cable and plug with 50 amp. All doable so far.
BUT, how the heck would I route the new 120 line from the service box to the new AC unit?
Anyone done this?
lewster 03-21-2017 08:06 PM
Anyone done this?
All RV 50 amp service arrangements are comprised of TWO circuits at 50 amps EACH, which requires 6/3 cable with ground that has 2 hot legs, one neutral and one ground feeding in to a 50 amp tandem breaker. The tandem breaker (basically 2 - 50 amp breakers linked at the re-set lever) provide power to two separate 50 amp bus bars in your breaker box.
Your 30 amp service is ONE circuit off 30 amp capacity using 10/2 with ground.
There is quite a bit more required of you for a complete a 30 amp to 50 amp conversion than the list you provided. :D
cwf 03-21-2017 11:03 PM
AS Lewster said, the 50 Amp upgrade has many steps.
I upgraded our 34' from 30 to 50 AMP. I also installed second AC. It is NOT to be taken lightly... do it right the first time.
I doubt your rig was built with the power and condensate lines installed... neither was ours.. so... The second AC power and condensate drain I ran on the inside of the skin and wrapped it in a weave loom to keep it tidy. Yes, it is on the inside, but it is clean...
Momma can now run everything at the same time... including curling iron and hairdryer... not a blip.
