-   1961 - 1963 Bambi (https://www.airforums.com/forums/f16/)
-   -   1962 Bambi Tire Changing? (https://www.airforums.com/forums/f16/1962-bambi-tire-changing-161725.html)
Gypsy Girls 01-20-2017 07:46 AM
Where do you place a scissors jack on my 1962 Bambi,when I change the tires?Also where and how many stabilizer jacks do I need and where to put them?Thanks for any help with this.[emoji4]
Sent from my SM-T580 using Airstream Forums mobile app
munimula 01-20-2017 11:27 PM
i would say axle or any exposed frame near the wheel. be sure to chock the opposite wheel. fyi you may need to deflate tire a bit to get it out of the wheel well. super tight there.
Dingo Girl 01-21-2017 01:02 AM
Don't put the jack on the axle.
There should be some small squares of aluminum riveted to the underside of the trailer next to wheel wells. These are the jack points.
Gypsy Girls 01-22-2017 09:06 AM
Thanks for the good advice.I did have to let the air out,really tight!Where do I put stabilizers and how many?Any help appreciated.Landeah
Antique Pedaler 01-22-2017 02:33 PM
I use 4 on the Bambi...2 on rear bumper, 2 on front frame.
Dingo Girl 01-23-2017 03:25 AM
You might want get tires that fit the wheel well with out deflating them. Unlt you carry an air compressor it will defeat the purpose of carrying a spare.
Dingo Girl 01-23-2017 03:26 AM
Unless not unit. Autocorrect strikes again. Sorry
