-   -   mattress choices ? (https://www.airforums.com/forums/f39/mattress-choices-15587.html)
vajeep 02-22-2005 06:24 PM
mattress choices ?
What type of mattress material do you sleep on in your trailer?? We are trying to pick between standard foam, innerspring, swedish foam and air. We have twin beds. Thanks in advance for your help.
Abe
Cedars 02-22-2005 07:09 PM
Hmmmm. I know this topic has been covered before.... we sleep on the originl mattress topped with two zone type, thick pads. Cheap, from WalMart. Works for us, very comfortable. We thought about the tempurpedic type ones, but we use an electric mattress and that would screw up the tempurpedic! My husband has fibromyalgia, and I have a bad hip so the mattress warmer is a god send for us!
And for the record, our Airstream is a 1983 Excella!
Elizabeth in Iowa
Condoluminum 02-22-2005 09:03 PM
Tempur Mattress Topper..
Our rear queen has the original Innersrping mattress, to which we've added a 2' thick high-density "memory foam" pad or "Topper"..
Gives the advantage of tempur pedic, without the weight and cost.. Available from mattess and bedding or linens places, or inline.. Cost about $50 for queen size (56"x74).. Works great, though without benefit of heated mattress... (We'd never be able to agree on temp controls for single mattress heater anyway..)
John McG
overlander64 02-22-2005 10:12 PM
mattress choice
Greetings Abe!
Abe
I have had my custom mattresses since 1996 in my '64 Overlander. Mine were custom-made by Lebeda Mattress Factory in Iowa. I supplied my local dealer with a cardboard template of the opening, and the mattresses were manufactured to fit the template - - there was an up-charge of $75.00 over the cost of the nearest sized standard mattress. I was so impressed with the comfort of these mattresses that when I moved to the Quad Cities in Illinois (2000), I purchased a new King-Size bedroom set for my home from the same model line as those in my Airstream - - when I moved to Southern Illinois last October, there was no question that the bed set would be moved as I have never had a more comfortable mattress/spring set. You can find Lebeda on the web at:
https://www.lebeda.com/
Good luck with your search for bedding for your coach!
Kevin
Cedars 02-22-2005 10:34 PM
Can you say "Dual controls"? LOL!!!
Elizabeth in Iowa
vajeep 02-23-2005 12:17 PM
Thanks Kevin,
We are going back with twins, but one side (mine..;-) ) is a litter wider by a few inches. The opening for the rear bath was to one side so we took advantage of the size difference. We did plan for a 12 volt heater for Mrs. Lincoln... I really like this web site!!!
hhuber 02-23-2005 05:22 PM
Life is Good!!
Abe,
When I got my AS thePO had recently had new foam cushions made. Caravels have a gaucho so there's no real chance of a "mattress".
Anyway, the cushions were like bricks and I just did not know what I was going to do. We went to one of the "marts" and bought a thick eggcrate mattress for about $20 or $30. It is really comfortable now. I could never deal with that at home but somehow I think when I get in my trailer it is so fun that everythings OK.
Heidi
