-   -   Anderson WD Hitch (https://www.airforums.com/forums/f238/anderson-wd-hitch-151454.html)
slowmover 05-30-2016 07:00 PM
Hogwash.
ROBERTSUNRUS 05-31-2016 12:03 AM
:) Hi, how can you blame Atwood when the Andersen hitch is the only one causing this problem????????? Clearly an Andersen problem.
ROBERT CROSS 05-31-2016 08:23 AM
“If your happy with what you're using......it's adequate.
If others are unhappy with what you're using......it's not.”
RLC
HowieE 05-31-2016 09:04 AM
Originally Posted by HowieE (Post 1799153)
And yes there is an issue with some of the Atwood couplers failing when using the Andersen. That is not a problem with the Andersen but a design limitation of the Atwood. A type of problem often encountered when a new concept is invented.
If one cares to read the above statement I do not say there is a problem with the Atwood coupler I say there is a limitation. If one accepts the dynamics at the interaction of the ball and coupler the limitation would be clear.
In all bar type hitches the coupler rests on the ball. The forces associated with the WD aspects of the hitch are transferred directly to the head of the hitch, forward of the ball, and then to the TV. With the Andersen hitch, while the coupler does rest on the ball, the forces relating to the WD aspects are transferred through the ball shaft with loads on the top and bottom of the ball shaft. It is this significant design difference that results in the failures of the Atwood coupler. It was not designed for that type of load. Not is not a problem, as there was no need to consider such loads when the Atwood was designed, that is a limitation resulting from the newer design.
Think of the limitations we would be under if we insisted that all creative designs comply with all old technology. The phone company worked under such constraints all the way from the hand cranked wall phone up to the 500 type desk set. Then someone invented the cell phone and cut the wire.
That is not "hogwash" that is progress and some adjustment may be required. Or do you really want to drag a wire around behind your cell phone?
The original question asked if anyone had experience with the Andersen. I have. I think my experience may even go a bit further than most using this hitch. I did encounter several questionable aspects but rather than sit back and claim the system could not work I made changes to my Andersen and forwarded those idea to the company. They incorporated the changes. And when my Atwood failed I found a solution and applied it and posted that solution for those who might be interested.
Why not my only other course would have been to return to a system I knew was not as good as the one I was using.
ROBERTSUNRUS 05-31-2016 11:46 PM
:) Hi, No; You didn't say there was a problem with the Atwood coupler, you said there was an issue. And now you changed your wording to Limitation. I see that as the same thing and now you are backing out with a play on words. Next you will you use the infamous excuse that we took your words out of context!
I don't know about you, but my cell phone is connected to a cable every night; Your's must be solar powered. And when traveling, I do drag a cable around, called a charger.
HowieE 06-01-2016 09:12 AM
I will stand by my original statement and trust that those who read it, without prejudice, will understand my comment.
polarlyse 06-01-2016 09:51 AM
I'm dusting off the boxing gloves. End Round 1
kd7trx 06-01-2016 12:56 PM
Anderson WD Hitch
HowieE - I recently went from a Reese Dual Cam to the Andersen for our 19' Bambi, now towing with a new diesel Canyon.
When researching a new wd system, I talked with a fellow at Andersen to inquire about their note about certain Atwood couplers. He said there is not a problem if a close tolerance pin is used on the lock-down lever, so did that. We just returned from our first long distance tow, and am very happy with the hitch's performance.
Curious what you suggest, if I should consider any other changes to improve the ball to coupler connection? I don't want to spend a day searching your posts to find the one you refer to above.
Thanks.
HowieE 06-01-2016 01:31 PM
There are a couple of locking systems used on ther Atwood coupler so I can't say across the board. The failure point on the Atwood 8800 is the "Shark Fin". That potential failure is a function of the load on the coupler and the roads you travel. I have a 34 ft trailer and travel a lot in Pa., the worst roads in the country as voted by the truckers association. My combination is putting a significant load on the coupler while transfer weight to the front axle of my TV. You are not operating under these conditions and thus I don't see a big problem in your case. All I would say is inspect the Shark Fin periodically. If it is wearing that wear will show on the lower front edge of the fin. Use the pin as suggested. That is what I am doing with my daughter's trailer
Every mechanical system ever invented has it's failure points. If you know them you can manage them whether it is changing the oil in your engine periodically or watching the wear on your tires.
Madarain 06-01-2016 02:43 PM
I was amazed as I read about your experiences. I too have an Andersen WD hitch and have used it for several years both with a smaller trailer and now our 23' flying cloud with no performance problems whatsoever. We did have to get a larger hitch ball for the Airstream trailer and we did just replace the friction material because I found we could do so for free. Otherwise the Andersen WD Hitch has been great. It's quiet and works perfectly well for us.
One especially curious comment makes me wonder what is different about our set up compared to what you had. You said "...The urethane bushings squeezed down so bad they began to fail". I don't understand how that's possible if the bushing housings were installed at the correct distance from the ball (specified in the setup directions) and the bushing bolts were always tightened to the correct number of threads (6-7 exposed threads, I think). I couldn't help but wonder if something else is different between our two setups.
SpletKay06 06-01-2016 09:15 PM
Well thanks for the info everyone I decided to order it today well see how well it works
dkottum 06-01-2016 10:48 PM
Originally Posted by SpletKay06 (Post 1799118)
I have a 2015 ram 1500 ecodiesel with full air ride. Im currently not using a wd hitch at all and it tows great front axle is 3400 but rear is axle 4400 so im a little overloaded. My trailer came with a resse wd hitch and it terrible makes the trailer ride horrible. When I first bought it and towed it home 280 miles nothing moved in the trailer and it towed great but then I setup up the wd hitch and everything moves around, it turns poorly etc. All im looking for is to lower the tongue weight a little and some sway control wouldmt hurt.
You have 1,000 lbs greater load on your rear axle than steering axle, and you are over rear axle rating by 500 lbs.
Chrysler may be sending an email advising you that you have been nearly 1,000 lbs over GVWR. You need a w.d. hitch that actually works, while taking another look at trailer and truck loading.
We use a hitch with conventional w.d. bars, our front and rear axles are within 40 lbs of each other. Our FC 25' Airstream and hitch add 820 lbs to our Ram 1500 Ecodiesel with weight distribution applied. This would not be possible with our previous Andersen hitch, the leverage is not there.
SpletKay06 06-02-2016 12:18 AM
Chrylser has no idea that my truck is overloaded that's a myth that these forms have created. If they did I would have got one about a year ago.
Adventure.AS 06-10-2016 02:45 PM
I have just purchased a 2017 Sport 16 and my TV is a Jeep Wrangler 4dr with the factory Max Tow package. I appreciate the information in this thread and others (especially from @HowieE). I have received information from two dealers that I may not need a WD hitch as the Sport only has a 350# tongue weight, which is within the recommended limits for the Jeep. I have previously towed a T@B teardrop that has a 250# tongue weight and when towing you wouldn't even know it was there. I am hoping for the same experience with the Sport 16.
SpletKay06 06-10-2016 05:19 PM
Unless you reinforce your hitch I dont think a wd hitch on your jeep is a great idea the hitch mounts with four bolts and clamps around the rear crossmember. Instead of mounting to both frame rails like on a truck. But it should do just fine.
dkottum 06-10-2016 06:31 PM
You're only a couple of hours from the best Airstream hitch experts in North America. Contact Can-Am Airstream in London, Ontario, they have set up hundreds of similar combos and will help you.
BTW, they tested the Andersen hitch and will not use it with concerns about a disconnected trailer.
https://www.canamrv.ca/contact-us/
slowmover 06-10-2016 08:22 PM
Anderson WD Hitch
There are pics on this site with a JK Wrangler towing a 34'. With a proper WD hitch.
Call Can Am.
SpletKay06 06-10-2016 09:30 PM
Call Can Am.
The JK wrangler is only rated to tow 3500 lbs do more research before posting that
slowmover 06-12-2016 11:19 AM
Anderson WD Hitch
Do you know the axle/tire ratings? I'm old enough that there was once no such thing as a tow rating. Or, how things were once done is different than now. What is at present "current" is not an improvement.
Or the truth.
