-   -   need advice!!!! (https://www.airforums.com/forums/f427/need-advice-151448.html)
lephil 05-28-2016 08:43 PM
need advice!!!!
Hi all,
I started gutting my '59 overlander for restoring and I just need to know if I keep the original water heater? or if I put a new one (already got it). But the shroud is one of my concerns with a new one...I want to keep the shell as original as possible.
mandolindave 05-28-2016 09:18 PM
I'm a little confused
If it is the original water heater, you should replace it.
If the shrouds ( exterior access doors ) have similar vents,( or no vents ) you can use either
If you have to use the new door, you could paint it silver.
