-   Roof Vents, Skylights & Fans (https://www.airforums.com/forums/f455/)
-   -   Roof Vent Screens (https://www.airforums.com/forums/f455/roof-vent-screens-14976.html)
walter1 12-23-2004 11:04 AM
Roof Vent Screens
I’m rescreening the roof vents on my 64 Safari. The square vents and rectangular Vista view. The screening part is straight forward.
Where can I obtain the aluminum grommets that the 3/8”shaft for the Ladeau opener handle sticks down through?
The original grommets are 1” outside diameter and have 9/16” center hole.
All I can find are regular hardware store type, brass, tarp corner grommets which don’t have large enough center hole.
Also, how do I install the grommets, special grommet tool?
walter1 12-23-2004 11:27 AM
Oops, my rectangular vent is an Astro dome type
63flyingcloud 12-23-2004 12:50 PM
Washers
Walter: I don't know of anyone who stocks those grommets. I ended up using two washers per hole, one on each side of the screen. Superglue and clamp.
