-   -   Automatic night shades (https://www.airforums.com/forums/f240/automatic-night-shades-148445.html)
Sgkh1947 03-26-2016 03:23 PM
Has anyone had problems with the automatic night shades getting stuck on the sliding door? Airstream readjusted them, but they still get stuck.
summerwood 03-26-2016 03:52 PM
Yes..My unit is going in for service on Tuesday. The sliding door unit does no get stuck.... it just does not retract totally. I have two other night shades that do not retract all the way to the top and one shade that stopped completely approximately 1/2 way to the top. I believe on that unit the motor has malfunctioned since it blew a fuse. All of the automatic sun screens work perfectly however. I recently completed a 6 week 3500mi + trip and this was my only problem so I am quite happy with the Interstate's performance.
Ynefel 03-27-2016 05:51 AM
Yes - exactly that. The side door shades (both) are mis-adjusted and also get stuck. Other shades need minor travel adjustment because they come down too far and tend to crease. The AS is at the dealer now getting those and the backup camera mount fixed under warranty (as well as attending to insurance claims).
MILATV 03-30-2016 08:28 PM
Haha, yep mine too. And mine rattle and bugged the heck out of me. Had to put small piece of tape on the ones behind driver seat they were so bad! Seemed really cool at first - but I see these being huge issue in year 3-4 of ownership!
Mike
jdthor 04-02-2016 05:01 AM
The automatic shades have given us problems also, after 6 months ownership and about 6000 miles travel. The privacy shades crease and the screens sometimes stop too soon, either up or down. I am 3 hours from nearest Airstream dealer (Baton Rouge) so I might have to live with it until I can schedule the warranty fix. I have no complaints with this vehicle other than this.
Mcrid 04-02-2016 04:28 PM
I've had the same problems. The attached file may help. I also discovered that the blind tracks become loose and are the source for most of the rattling. The up and down limits are a real pain to get to them for adjusting.
Ynefel 04-02-2016 05:45 PM
Thanks for that manual!
Too bad the limits can't be electronically programmed like Somfy shades. I can't imagine getting to those screws for adjustment.
-Robert
jdthor 04-03-2016 07:27 AM
[QUOTE=Mcrider;1770889]I've had the same problems. The attached file may help. I also discovered that the blind tracks become loose and are the source for most of the rattling........................
Thanks Mcrider; I might fool with it some today if I can get to the limit controls. That's a good tip about the tracks rattling. I have something going on back there and I didn't think about that, so I will see if that is the source of my rattles.
BTW, we just got back from a week at Big Bend National Park, perfect time to visit if anyone is so inclined. The Spring Breakers are just about through drinking beer and carrying on and the Chisos Basin is getting back to its usual majestic self.
Mcrid 04-03-2016 06:07 PM
There are screws in the top cabinets that hold the side panels. You can remove these and tilt the panel out to more easily access the limit adjust. Good luck.
jdthor 04-04-2016 12:38 PM
Found the screws, removed the panel with the non-functioning shade. The problem is obvious. Somehow the wires got caught in the rotation and got stretched, snapped, including pulling the little plastic clips off the attachments. (these would be the clips that are supposed to keep the wires out of the rotation mechanism, I guess) I fould a couple of tiny broken pieces of plastic, function unknown. But the limit adjusters are easy to get to!!
Mcrid 04-04-2016 06:46 PM
At the end of the wires is a very small momentary close pushbutton that is used to program the blind to the controller. If it tore this off (as it did mine) you will need to improvise.
jdthor 04-04-2016 07:13 PM
Both programming push buttons (for both the shade and the screen) are torn off, but found. I can hopefully re-solder everything if need be. I sent an email to the manufacturer to see if any of this is covered in their warranty. If not I will try Airstream. If both are non-responsive I will cut and splice everything using the one on the driver side as a guide. If none of that works I will have a very expensive "manual" shade on the passenger side. Believe it or not it was those remote controlled automatic shades that caught our attention on the lot when we were sightseeing new models. Ended up trading a late model Eddie Bauer 28 AND an F150 FX4 for the Interstate, so those shades are important!
Mcrid 04-04-2016 07:22 PM
[QUOTE=jdthor;1771102]
Yep, it is nice out at Big Bend https://www.airforums.com/forums/f240...ml#post1756074
cjrdad 04-05-2016 06:44 AM
Same problem with my night shade on the sliding door. Mine is not stuck but came off the rail. It might have been from the repeated slamming when closing the sliding door.
slomanbob 04-06-2016 12:13 PM
We've had our AS for about 10 days. Took out for its maiden trip over the weekend. The PS rear nite shade won't retract now. Printed out the User Manual from the manufacturer's website. Tried to re-program as described on p. 9, but no luck. Have an appt on the 20th to repair. We also noticed two shades that need a "limit adjustment" so they won't crinkle. Other than that, we enjoyed our first outing.
Mcrid 04-07-2016 08:43 AM
Check for a blown fuse. I had the 5amp fuse blow so my rear door shades became inoperable. Replaced fuse and all is well.
slomanbob 04-09-2016 12:42 PM
Mcrider: Thanks for the suggestion. I've traced the wiring and both the PS mid & PS rear shades are powered by the same fuse. Inasmuch as the mid shade is working properly, I'm assuming it's not the fuse.
summerwood 04-10-2016 08:06 AM
Slomanbob...I have exactly the same problem after my recent 6 week trip...blew the 5 amp fuse and PS rear shade became inoperable. Replaced fuse and PS mid shade is fine. My rig is in for service now and I will let you know the cause of the problem PS rear shade
jarreau 05-20-2016 12:55 PM
Thanks for the manual download. Do you have to take off the side panel to get to the rollers? If so, is it easy to do... do they snap in somewhere?
Mcrid 05-20-2016 02:01 PM
Remove screws located in overhead luggage compartment. Then the side panel will pull away sufficiently to access wiring if needed. Limit. Programming switches can be reached without going to this trouble.
