Off Grid Electricity - A Minimalist Approach
If you’re full-timing with a microwave, hair dryer, electric coffeemaker - this exercise is not for you. You can easily spend into the low 5 figures for solar, lithium, etc.
But let’s attack this problem from the other direction - limiting demand in order to reduce the power system needed. LED lights: 4 amp/hours per day. Let’s say we average 4 hours a day running 2 lights. That’s more than I would realistically ever typically use, but at 6 or so watts each, that would be 1 amp per hour. Daily total so far: 4 amp hours. Propane refrigerator: 12 amp/hours per day Please correct me if I’m wrong, but I’ve read that on propane there might be a 0.5 amp or so draw for the fan and control board. I think this estimate is high, but let’s go with it. Daily total so far: 16 amp hours. Laptop and cell phones: 10 amp/hours per day Running through a small inverter, so there’s a conversion penalty. These things are very light users though. I think this would be more than enough to watch a movie or two with enough left over to check on everybody’s Facebook cat videos many times during the day. Daily total so far: 26 amp hours. Propane detector: 3 amp/hours per day Also not sure about this one. Feel free to correct me. Daily total so far: 29 amp hours. Water pump: 4 amp/hours per day Also not sure about this one. Feel free to correct me. Daily total so far: 33 amp hours. Furnace: 0 amp/hours per day. Sorry, this is the battery killer, so the Atwood has to go. Switch to catalytic, marine stove, heavy blankets, or aerobic exercises of your choice. Daily total so far: Still 33 amp hours. If you camp in the open (I don’t) in a sunny climate (nope again) a single 100 watt solar panel would probably keep up with this. A 1000 watt generator for a couple hours every few days probably would as well. Feel free to poke holes in my usage estimates. |
There is a good analysis here. Which suggests more along the lines of 50-60 AH per day, factoring in a little heat and not a huge desire to conserve.
Thanks for the link.
My point of view is that it's more effective/efficient to save an amp/hour than it is to provide it in the first place. The biggest power hogs are the furnace fan and the water pump. So - eliminate the Atwood for a huge gain in efficiency. Conserve water (a necessity anyway) and there goes another big user. Replace anything electric that has a heating coil or a motor with something more efficient. |
We don't use any of the small kitchen or bathroom appliances except occasionally a slow-cooker when we're plugged in. Nuthin' wrong with wet hair, and we use a drip coffee cone and filter that drips coffee into an insulated pot or thermos.
We save on battery power and propane while boondocking by freezing blue gel pacs in the freezer at night, then turning the fridge off completely during the day, and inserting the frozen gel pacs amidst the food, as we would with a picnic cooler. The fridge is incredibly well insulated, and we've never had food warm up or go off with this system. Then at night we re-freeze the gel pacs for the next day. Usually they're still mostly frozen. at the end of 12 hours. With this system, we turn off the batteries (2 6-volt) during the day from the main switch if we're out hiking or whatnot for the day. When the furnace is needed, we keep it at a really low setting (like 63F) and pile on an extra comforter or sleeping bag overtop the regular bedding. Small electronics like a cell phone, Kindle, or laptop can be recharged in our vehicle's port while driving, or with a small portable solar gadget. Outdoor grilling and salad/sandwich type foods save on the stove exhaust fan. If the batteries are 100% charged prior to boondocking, we've been able to camp for 5 days with this system without having to use our generator. Then we bring along a battery recharger that we can plug in when we're at a RV park. (No serious solar yet, but we're intrigued.) |
I wouldn't say efficient as much as I would say, cheap.
Really? Would it make sense to power up enough to run a clothes dryer?
I have managed to deplete two deep cycle fully charged batteries in 3 days with minimal usage, by accident, converter was unplugged with out my noticing it. Normally take the amps your batteries have and don't use more than half before recharging. |
Real world experience tells me 1.) you're exaggerating 2.) 100-watt panel won't keep up with 60 AH a day in real world conditions if full timing. Considering that a GS100 panel only puts out 5.7 amps of power. How many hours of full sunlight do you need to top back off?
Maybe some weekenders. |
Just normal summer camping we use about 25% of our battery per day. With 2 group 24's at 80 amp hours each that come to about 40 per day. Now I have 400 Watts of solar and in full sun it's all returned by lunch. But in inclement weather a minimalist approach is required. (Need better batteries)
When I am boondocking for any extended period, I turn the water pump off to conserve battery power.
Turn the pump on only when you have to have it, use dishwater to empty the toilet....minus the extra water and pump use from flushing. :bb: I also turn off my TV antennae. Maggie |
A simple marine manual foot pump or hand pump would eliminate the water pump from the demand side and add redundancy to your system. LED lights are a given. Agree about the forced air heating. Providing battery/solar/generator capacity for a furnace is not wise imo. A catalytic heater makes much more sense to me. Thanks to NW Getaways for addressing the topic! |
The water pump takes no power when not pumping water, so there is no need to turn it off when you are out, or inside not using any water.
When the pump runs, it takes 4 to 7 amps. It pumps about 3 gal/minute when operating. So, in 10 minutes it can pump a 30 gal fresh water tank dry. 10 minutes is 1/6 of an hour. So, if the pump takes 6 amps per hour, 1/6 th of that is 1 amp hour to pump 30 gal of water. If it pumps the same 30 gal over two days, the same 1 amp hour is used over two days. The water pump is NOT a big user of the stored battery energy. And it does not take any power when it is not running, so turning it off and on when you want to get a cup of water, or flush the toilet, does not use less battery capacity. |
Great tips everybody!
My estimate for the water pump was way off. How about the refrigerator? |
This thread talks about some heating options. Really like the Dickinson.
Refrigerator use is more variable. Some of the older models used up to .75 amps 24/7 and some of the newer ones as little as .35 amps and then only when the burner is operating. Some have fans, some do not. The factor fan takes way too much power, in the range of 0.4-0.5 amps, but replacement fans can take as little as .02 amps. So, generalizing about the total amp hours is very difficult.
The electronic ignition water heater also takes 12 volt power when the burner is operating, but none when it is not. I don't have the amp use at my fingertips, I will have to look it up. But it is not a large user overall. |
I just try to use the water pump only when I must...every bit of battery power saved matters, is my logic.
If I run water with the pump to wash and rinse the coffee pot and a few dishes in the morning, I can use that same water to empty the toilet during the day....minus the pump running and fresh water being used from my finite supply. :bb: I don't have a gauge that tells me when every bit of battery usage occurs, and how much, and I am glad as I think I would drown in the minutia of it. :lol: Maggie |
Amp Usage
Maybe this will be useful:
The range lights can be replaced with LED for about a 90% savings. The refer number is without the cooling fan running, just the logic board and ignition circuit. These are from actual amp readings in my 25 footer. The running lights are for the trailer only and do not include a tow vehicle. (Mine are switched so I can turn them on when unhooked. Good light for connecting hoses and cables in the dark.) Fantastic fans are on the highest setting. The pump monitor is the MicroPulse unit. The under cabinet, shower and bath lights are both halves on. The 0.14 amps is when using only half the fixture. Item Amps Furnace 7.60 Refrigerator 0.78 Water Pump 8.70 Pump Monitor 0.06 Bathroom & Shower Fans 1.20 Fantastic Fans 3.00 Lights Main Overhead (High) 1.53 Main Overhead (Low) 0.31 Bedroom Overhead (High) 0.56 Bedroom Overhead (Low) 0.12 Reader Spotlights 0.16 Under Cabinet, Shower, Bath (ea) 0.27 Above at 50% 0.14 Range Light 1.71 Step Light 0.06 Patio Light 0.11 Running Lights 1.20 Range Fan 2.11 TV Antenna Booster 0.07 Stereo (Clock Display Only) 0.74 Cheers |
Amp Usage and an unrelated heating solution
A bit more information: On the overhead lights, each puck draws about 0.14 amps on the high dimmer setting and 0.04 amps on the low dimmer setting. The numbers I previously provided were for a 25' and I realized that each trailer might have more or less of the pucks installed.
If your thermostat is like mine, it is capable of handling more than one zone. You can install a temperature sensor in the area where your pipes are most likely to freeze (like in the area just below the floor where the water lines pass to the basement) and then set the temps for that area down to about 50°F or less, if you thermostat will allow. Leave your furnace on but then heat the living area with whatever options you choose. Your thermostat, if properly set, will be monitoring the temps in the basement and kick on when it needs to. If you thermostat isn't capable of zones, you can pick one up at Lowes or Home Depot that will. Just be sure it can include the heat pump if you have that option and want to use it. |
We are full-timers but if we are not using the water pump, hot water heater they are turned off. The habit is instilled in us so it works for us. We put a lot of gray water in the black tank. I think that helps the tank.
Everyone has to find their own comfort zone. I am comfortable turning things off when not in use. |
