-   -   City Water In Box (https://www.airforums.com/forums/f163/city-water-in-box-147604.html)
Bbelk 03-06-2016 08:20 AM
City Water In Box
I have a 2010 27FB Classic without a spec of rust on it, except for the box where the city water comes in.
https://lh3.googleusercontent.com/Tp...Ui8dhg=s480-no
It is steel and rusting badly. It won't last much longer. This however is not my immediate problem. This is:
https://lh3.googleusercontent.com/Sp...H0c4iw=s480-no
The quick connect fitting was left in too long and has corroded into place and I can't get it out.
Can anyone tell me how to get into this box. Short of sawing a hole in the bottom of it, I can't figure out how to get in there.
Bbelk 03-06-2016 09:27 AM
When in doubt
When in doubt - break out the saw.
https://lh3.googleusercontent.com/fl...w=w640-h480-no
After getting in there, I can see that there was no other way to get in there. This stuff was put in below the floor at the factory with zero play.
I have to find one of these that is within about 1/4 inch of the same depth or I will have to cut into the PECs and give myself some play.
https://lh3.googleusercontent.com/_Z...Q=w640-h480-no
