-   -   1963 Avion T-27 How do I remove the built ins? (https://www.airforums.com/forums/f7/1963-avion-t-27-how-do-i-remove-the-built-ins-147467.html)
Mollyki 03-02-2016 07:59 PM
I need to take all the cabinets and beds out to fix the floor. I want to take these out intact so I can reuse them. It looks like they might be riveted, but I can't really tell. Any ideas? Also, I want to rewire everything. Do I have to remove inner skin to do that?
Beaker63 03-02-2016 08:38 PM
Hey Molly,
I also have a 63 Travelcader, if I recall correctly everything is held by screws. You need a #2 clutch head bit to remove them. The screw heads have a sort of figure eight pattern inset in them. They are probably filled in with paint and are not easy to remove. Be patient, vice grips help.
Tim
Becky B. 03-02-2016 08:41 PM
...and yes, you will have to remove your inner skins to rewire...
