-   -   Argosy interior painting (https://www.airforums.com/forums/f46/argosy-interior-painting-146590.html)
Andersojd 02-08-2016 02:16 PM
Seen several general thoughts on painting, wondering if anyone out there has had good or bad luck with particular products. Ours is a 72 Argosy 22, interior walls in good shape except for a ton of rivet holes. Any thoughts on a filler for those and a primer/paint would be helpful. Familiar with Bullseye, thought we would try that underneath followed by some good interior oil paint n top. Also could use an idea on how to coat the smooth yellowed plastic interior end caps. Thanks for the help Jim
jonnyo 02-08-2016 03:48 PM
Put some rivets in the holes
Primer: BIN ... Amazing product. Stick strongly and cover stains
Than you can put any paint, water or oil based.
For the plastic end caps, krypton plastic spray paint does amazing work. Simple and stick very well. Cheap and easy
