-   -   black sticky gasket? (https://www.airforums.com/forums/f456/black-sticky-gasket-14221.html)
crgintx 10-15-2004 11:47 PM
My Alclad skin has arrived from AirParts. I've cut it to length. I've drilled and removed most of the rivets from the damaged area. There is what appears to be a black sticky gasket with fiber in it. Where can I get some of this gasket at?
markdoane 10-16-2004 07:58 AM
Try this place: https://www.austinhardware.com/produc...478&pf_id=3250 (They're in Dallas, not Austin)
Or do a search on 'butyl tape'.
andoboba 10-16-2004 09:43 AM
Sticky black outdoor carpet tape
This sounds like carpet tape which is designed to be used outdoors. It is 100% weather proof! The tape looks like an impregnated black strip of fiber mesh. Good luck getting it off of anything. All big hardware stores should have it. I just used a bunch to apply R-4 aluminum sheet insulation to beef up and hold in the original fiberglass. Great stuff!! The tape sticks to dirty aluminum GREAT!
crgintx 10-16-2004 07:50 PM
Much thanks
I'll have to see if there's a dealer in Houston who stocks it.
overlander63 10-17-2004 06:41 PM
I have used this stuff when repairing automotive A/C units. You can try an auto a/c parts supply store, if you can't find it anywhere else.
