-   General Motorhome Topics (https://www.airforums.com/forums/f160/)
-   -   Windshield wipers (https://www.airforums.com/forums/f160/windshield-wipers-13880.html)
tandemfish 09-21-2004 02:44 PM
Windshield wipers
Probably another dumb question, but I can't figure out how to switch on the passenger side windshield wiper. upon looking under the hood, it appears that both sides work independently. I this correct and if so, which knob operates each wiper. To the left of the steering wheel, I have a wiper knob and a washer knob. Also, my washer is not working. Any suggestions? Thanks again, everyone!!!!!!! You guys are great!!!
ALANSD 09-21-2004 06:06 PM
Mine has two knobs one for each wiper. The left knob for the left,etc.
As for washers it is common that the hoses are shot, or the nozzles are plugged up or both.
Go under your hood and find where the rubber hoses tee together, and then go into the bottle. If you disconnect the tee, and have someone press the washer button, it might spray some out of the line. You can isolate where the problem is. If it does shoot out some, then you know the nozzle or hose endis plugged and compressed air might clean it out. If not the pump may be shot. See if it makes a sound when it is supposed to be pumping. Mine has bad hoses. I bought a long squeegee and keep the windows pretty clean with that. The washers were low on my to do list.....and after 3 years I haven't gotten to them yet:)
Astrodokk 10-06-2004 07:56 PM
Mine also has two knobs on the left of the steering wheel, one for each of the wipers. The washer works while the wiper is turning and you have to push it in almost like a pump, although i found out it's actually electric.
