-   -   Mystery leaks. (https://www.airforums.com/forums/f456/mystery-leaks-136556.html)
msasse 06-12-2015 06:10 AM
Mystery leaks.
We have noticed a couple leaks in our 1981 international. 1 leaks happens when. It rains heavy on the front side window appears to be leaking from a seam up top then running down the inside window frame the second leak happens when a/c is turned off after running water is leaking down in to window and dripping down inside camper into bed is there some type of silver sealant we can use on roof seams. Thanks
Lumatic 06-12-2015 07:27 AM
Silkaflex or Alcoa Gutterguard
