-   -   Dining table to recliner restoration (https://www.airforums.com/forums/f7/dining-table-to-recliner-restoration-135751.html)
Mrjkq 05-27-2015 07:14 PM
Has anyone done this, remove the front L shaped sofa/dinete & replaced it with a sofa with double recliners & a couple small portable tables for dining
in a 25 ft FC.
lsbrodsky 05-27-2015 07:15 PM
Try search
Larry
SteveSueMac 05-27-2015 07:51 PM
Yes, it's been done in many trailers.
recliner conversion 25 flying cloud airforums site:www.airforums.com
The search feature in the forums (app anyway) isn't too effective so the link above is a Google search phrase you can enter and it will return several threads with examples you can learn from. Are you considering something like this?
Good luck!
AWCHIEF 05-27-2015 08:00 PM
Dozens here alone. Unknown number elsewhere. Couple of dozen screws and it comes easily apart. I removed the front section, only needed room for one chair.
KathleenBenk 11-29-2015 06:43 PM
Did you do this? Who did it and what was the cost? We are looking to have our 2009 Classic, 27ft. FB dinette area taken out and a sofa or two recliners put in.
Kathy Benken
AWCHIEF 11-29-2015 06:48 PM
Kathy, yes I did the work myself, zero cost. Already had the Lazy Boy at the house.
Denis4x4 11-29-2015 08:42 PM
Took about 2 hours to strip out the dinette in a 25FB. Another two hours to clean up the aluminum shavings and glue down the flooring. I did make a special end cap and relocated the furnace ducting on the street side lounge. Still annoyed about the sloppy crap that I found under the cabinets. I guess the motto is "out of sight, out of mind" on the assembly line.
sheriff1 11-29-2015 08:52 PM
Attachment 253065
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
