-   Land Yacht/Legacy Motorhomes (https://www.airforums.com/forums/f312/)
-   -   CB Antenna Replacement 2005 Land Yacht 30' MH (https://www.airforums.com/forums/f312/cb-antenna-replacement-2005-land-yacht-30-mh-135376.html)
kenajen 05-20-2015 12:55 PM
We recently purchased a 2005 Land Yacht 30' SL and found the original mag-mount CB antenna broken at the magnetic base. I tried to pull the new cable through the roof to the drivers overhead cabinet with the old cable with no luck. I cannot believe that AS would tie down this cable behind the headliner/cabinets etc, rather than let it free float for future replacements.
Any help would be greatly appreciated.
PS I'm a Amateur Radio Operator and don't do much CBing these days but it may come in handy someday.
woodytwo 06-05-2015 11:44 AM
I believe that the cb antannae's were a post factory/ after market installation so you will probably need to do some cabinet removal. Keep us posted as to what you find. Thanks.
kenajen 06-05-2015 04:00 PM
Thanks Woody! I will be digging in this next week to see why it won't pull through. I hate the thought of cabinet removal for this short distance between the radio and the antenna. I might try to fish it through before any serious cab work.
kenajen 06-08-2015 01:50 PM
I found the path for the antenna coax from the driver's overhead to the roof. You have to remove the speaker left of the driver's overhead cabinet. This gives you a 4" hole to pull from for access. I had to cut the PL259 coax connector off the new antenna and tape to the old to pull from the roof to the cab. Also there was a wire that tangled around the coax when I first tried to pull. :) Take care!
Trident 07-16-2015 01:48 AM
I have a 1998 LY 30 and the antenna mount comes out the SIDE jest above the driver door. Antenna is on a mount made for this installation looks good and you don't punch a hole in the roof or move any cabinets the coax runs up the column to a space to the left of the drivers head then out to the Ant. mount.
Hope this helps.
Airstream12557 07-16-2015 05:24 AM
Trident -- I installed my CB antenna above the drivers door. Straightforward instllation. Installation looked good.
Trident 07-17-2015 12:33 AM
Good choice !
