Safety Flasher Lights?????
My 1985 325 MH does not have the safety flasher or hazzard lights do not
work at all. I have good stop lights and tail lights and turn signal lights. Just wondering if anyone has any suggestions as to where to start looking. I have changed the flasher control with the blinker light control and makes no dif- ference. Thanks for any ideas. ODD |
Normally, there is a separate flasher unit for the warning flashers. Check and see if it is OK and the fuse feeding it is OK
Flashers???
Thanks for the quick reply,
I did check the round 3 pronged flasher module. Thats ok I will look for a fuse in the system. If its behind the fuse box it will be a real bear to get at. Will see what I find. Thanks ODD |
Did you check both flashers? The warning light flasher is probably a 2 prong.
