-   -   Water pressure regulator (https://www.airforums.com/forums/f240/water-pressure-regulator-126795.html)
FunWaggin 10-19-2014 08:18 PM
We are proud new owners of a 2014.5 AI. I am wondering if the AI has a built in water pressure regulator? I recall the sales guy mentioning it but I want to be sure I understood correctly.
dkottum 10-19-2014 08:25 PM
It is built into the external city water receptacle where you hook up. I think the receptacle says it is a pressure regulator there on the outside.
FunWaggin 10-19-2014 08:27 PM
Thank you for the rapid reply. We are heading out tomorrow and feel better knowing that.
PharmGeek 10-19-2014 08:34 PM
I started to use one now in addition to the one in the AS as I believe (although not totally sure) that high water pressure damaged one of my water hoses
dkottum 10-19-2014 08:59 PM
Pharm, your water hoses are outside the trailer and not protected by the built-in unit. There is a good chance your hose damage occurred from expansion within the hose from heating of the sun, so a pressure regulator at the campground spigot would not have protected that either. There is really no reason to use an additional pressure regulator.
PharmGeek 10-20-2014 07:00 PM
Ohhhh - I failed to consider that - I guess in hot weather if off and about can turn off and unscrew ?
I don't see why high pressure from the spigot could not damage the water hose (probably a dense moment)
Protagonist 10-21-2014 08:34 AM
Physics: Water only expands by 1.25% when heated by 100 degrees, as long as you don't heat it enough to boil it. That's not enough to rupture a hose, not even a hose that has been softened by direct exposure to the sun.
It has to be the pressure in the hose, especially when you're not using any water so all of the faucets inside are closed and the pressure has nowhere to go. It's force of habit to open the spigot at the service pedestal all the way every time you hook up, but if municipal water pressure is unusually high, you can just open the spigot partway and thereby reduce the pressure in the hose.
Panama Red 10-21-2014 08:39 AM
You'll only reduce the amount of flow by not opening the spigot all the way. With everything in your camper turned off, the pressure will build to whatever the supply pressure is, even if you barely crack open the spigot. In electrical terms, it's like voltage and current. You still have the same amount of force pushing it (voltage) just not as much flowing through it (current). To reduce the pressure on the hose, you have to put the regulator on the output of the spigot...
-Red
Protagonist 10-21-2014 08:42 AM
You're right. Just goes to show that it's a good thing I'm retiring at the end of the year if I keep having senior moments like that.:lol:
Panama Red 10-21-2014 08:44 AM
Lucky dog! I'll take those senior moments if it means I get to retire... Just under four years now.
-Red, getting short-timers a little early...
dkottum 10-21-2014 08:49 AM
I've had a hose expand a permanent balloon at home lying in the hot sun when the supply spigot on the house was off and the spray nozzle was also off trapping whatever city pressure was there, then softening and adding the thermal expansion of the sun.
It was a cheap hose, like the ones rv's use. I don't know what else could have caused it.
dkottum 10-21-2014 08:52 AM
Protagonist. By the way, congratulations on your upcoming and soon-to-be retirement! Senior moments only mean life is less stressful, it's wonderful.
moosetags 10-21-2014 09:14 AM
Even though the Airstream has an internal water pressure regulator, I still use an external one attached to the water supply spigot at the campground. I am probably being overcautious but it just makes me feel better.
Brian
dkottum 10-21-2014 10:25 AM
Brian, I used a second one for awhile too, then asked myself why. With no good answer I got rid of it.
73shark 10-21-2014 11:29 AM
Are we sure that the Interstates have the built-in regulator?
UKDUDE 10-21-2014 11:55 AM
The 2014 Interstate Parts PDF, which I downloaded from the Airstream website, does mention a "City water fill w/regulator, chrome".
CDONA 10-21-2014 12:01 PM
My first time on my Alfa, I ran an external pressure reducer into external water filter into the built in PR, and lived with weak flow from the shower.
Once I realized there were two inline PR's, I pulled one and got more than the dribble. The water pump had better shower flow.
My new EB the water inlet/PR started leaking back in Jan. I pulled it from the skin, tightened it (4 screws on two piece plastic construction) and then left it loose to dry out for a couple of weeks. It started leaking again this month, so I replaced it on my dime, cheaper than a trip to Tucson for warranty.
I'm keeping the old one to seal up with silicone as backup.
joemikeb 10-21-2014 05:35 PM
My 2013 came with an external pressure regulator in a plastic bag along with some other small items such as the hose and nozzle for the external shower. I use it and have no low water pressure problems.
PharmGeek 10-21-2014 05:38 PM
I use external as well and water pressure is un affected as far as I could tell
Never bad a problem with water pressure yet
I still am not clear why high pressure at spigot could not damage a water hose
dkottum 10-21-2014 07:18 PM
This is from your (2014) Interstate Owners Manual:
"Your plumbing system has a built in pressure regulator to protect your lines and faucets from extremely high pressures on some city water systems. An after-market external regulator is not recommended, as it could lower the water pressure at the inlet and thus to your faucets and shower."
