-   -   Creeping Crud (https://www.airforums.com/forums/f441/creeping-crud-123654.html)
Aironius 08-08-2014 07:45 AM
Creeping Crud
My new-to-me 2001 Bambi has white surface oxidation creeping out from the bottom edge of the oval metal badges on both sides. It extends a half inch out under the mylar stripe, causing a bulge. Looks like the aluminum is corroding, possibly from salt trapped behind the badge? What do folks commonly do to halt and remediate? I'm guessing the emblem has to come off to clean it up.
Larry C 09-02-2014 12:02 PM
Go to the search function and type "filiform" you should find more than you care to know about it.
dznf0g 09-02-2014 12:04 PM
It's creeping crud alright!
Gene 09-02-2014 12:45 PM
Check out this thread: https://www.airforums.com/forums/f142...ams-31743.html
It will give you something to read for the next month, but there's useful information about how to treat corrosion.
Gene
dkottum 09-02-2014 12:54 PM
Like all things Airstream, it's treatable and repairable. Good info on repair in the threads mentioned, but there's a lot of complaining to dig through to find it. No sense in starting another thread on repair, it will undoubtably go the same way.
