-   -   Atwood water heater electronic ignition problem (https://www.airforums.com/forums/f163/atwood-water-heater-electronic-ignition-problem-122324.html)
Deairstream 07-09-2014 05:32 AM
My hot water heater will turn on and make hot water. The problem it is failing more and more to turn on to maintain the hot water temperature. I will have to turn the switch off and on and it will ignite the burner again.
