-   Tires (https://www.airforums.com/forums/f438/)
-   -   Seeking Tire Advice for Single Axle (1964 Airstream 4000lbs) (https://www.airforums.com/forums/f438/seeking-tire-advice-for-single-axle-1964-airstream-4000lbs-120387.html)
travelfables 05-28-2014 08:27 AM
I'd love some tips from Vintage Owners regarding tires.
Which ones to order, which wheel size etc.
Things to note:
  • My rig is a 1964 Safari SINGLE AXLE. (it had some old tires on it that were hell to take off, so tire width is a real issue.
  • I'm going to have to purchase both wheels and tires
  • The weight of my rig (according to the vintage documents found in it) is 4000lbs.
(other notes, As a long time RVer in Some Other Brand , I will not run anything with Carlise or Firestone in the name, and I realize that there are tons of tire threads here and trees in the forest.)
Help, hints , advice and current info from Vintage Single Axle Airstreamers greatly appreciated.
Jammer 05-28-2014 02:17 PM
If you had trouble getting the tires off, chances are that you need a new axle, also.
If possible weigh your rig before buying tires.
If you want something that looks stock, I'd suggest this wheel and the accompanying hubcap:
15" Trailer Wheel
Reports on fitment vary from one trailer to the next. You may be able to fit 225/75R15 trailer tires, which would give you the most capacity. If they would rub you may have to use 215/75R15 or 195/70R15 light truck tires.
There are limited selections of brands in these sizes. I have Goodyear Marathons, which have worked out for me, but lots of people hate them.
travelfables 05-28-2014 04:14 PM
Cool Jammer! Thanks for the Tip. I think my removal issues were due to the random junk that was on the rig, and the place it was in. Axle has a bit of life left in it. Has anyone put a 16" tire (and wheel) on one of these? Yes, a slender one? I think the (front to back) clearance is fine if I cut away a silly lip on the bottom of the trailer hub that serves 0 purpose? I don't care about the Vintage thing, just function, and quality. I've run Marathons on other non-Airstream rigs in the past, and was happy as well.
r carl 05-28-2014 05:57 PM
These would be great for your camper.
https://www.tirerack.com/tires/tires....rtnum=700R5215
SteveSueMac 05-28-2014 06:06 PM
While that link doesn't specify P or LT, the description speaks of use in passenger cars and light trucks. If that makes it a "P" rated tire, you would have to derate that 2040 lb capacity by 10% if used on a trailer - bringing its load carrying capacity to 1836 lb per tire.
r carl 05-28-2014 06:40 PM
Its a LRD LT tire. All the info is on that link. I have them on my 30' Avion. They are heavy duty I assure you!
