-   -   1 more question on floor replacement? (https://www.airforums.com/forums/f36/1-more-question-on-floor-replacement-12028.html)
jperryfly 06-15-2004 02:51 PM
I have some holes in back of trailer in floor. If I take off the trim strip aluminum and then unscrew osb can I get it out and slide in a sheet of plywood? It looks like 3/4" thick, is that right for a '85 Sovereign? Why was AS using osb anyway?
Ken J 06-15-2004 04:04 PM
Do a search for "clamshell repair" - I think that describes what you are referring to.
Ken
Joe Z 06-15-2004 09:59 PM
jperryfly - Check out this thread:
https://www.airforums.com/forum...ad.php?t=11903
I have an '87 Sovereign with a similar problem. If your floor is the same as mine it is 5/8 OSB with the edges that go under the aluminum "U" channel in the front and back of the trailer routered down about an 1/8". After two dealers botched the repair job I decided to do it myself. Joe
