-   1960 - 1964 Globetrotter (https://www.airforums.com/forums/f155/)
-   -   Main Door Pins for 64 GT (https://www.airforums.com/forums/f155/main-door-pins-for-64-gt-120277.html)
AlumiDillow 05-25-2014 06:36 PM
Hi all, this is my first post on Air Forums. We are the proud owners of a very original and very well kept 64 Globe Trotter. This is our first AS and we LOVE it. I have noticed the bottom of the lower hinge pin is broken off. Something I learned from this forum :) that due to concerns of break ins by removing door the pins have holes drilled in the bottom of the and a retainer pin was used. Looks like it broke off there. this shorter then normal pin causes some binding of the bottom of the door hinge when the door is opened. Where can I find replacement pins for a 64? Looked at Inland and Vintage Trailer Supply but have not found anything for a 64.
tmeagle1 07-08-2014 03:53 PM
Not sure if you got an answer yet, I hope so, here's a link if you haven't found out where to purchase them yet: Airstream Door Hinges
AlumiDillow 07-08-2014 10:08 PM
Ah Thanks but I just need pins not the hinges. I found these which work really well and with the screw in the bottom of the pin there is less chance of them falling / being pulled out.
Accurate MFD Products Z4890 Architect Bolt 8 32 | eBay
