-   -   Solvent to remove 1963 factory sprayed black tar (https://www.airforums.com/forums/f456/solvent-to-remove-1963-factory-sprayed-black-tar-120160.html)
Aktundra 05-22-2014 06:09 PM
My 1963 Bambi has a sprayed "black tar" goo, used to seal the floor, "C" channel, and outer shell. I have done a shell off restoration, ready to reseat the shell, and want to reseal the shell/belly wrap/floor.
Can anybody suggest a solvent to remove the old black tar material, so I can get a good clean bond with a new sealant ?
lonewolf1977 06-19-2014 04:30 PM
I had great results with Citristrip for that tar-like substance. I used the spray on kind, let it set for about 20 min, and the majority of it was wiped off with a paper towel. Using some mineral spirits should get off any residue after that.
