-   Airstream Classifieds (https://www.airforums.com/forums/f534/)
-   -   2008 Airstream Safari SE 27 - Washington (https://www.airforums.com/forums/f534/2008-airstream-safari-se-27-washington-119874.html)
keycitystrmr 05-16-2014 12:18 PM
Title: 2008 Airstream Safari SE 27 - Washington
We just listed our 2008 Airstream Safari SE for Sale on Airstream Classifieds.
Year: 2008 Make: Airstream Model: Safari SE Length: 27'
Looks great. Camps great. Tows great. Purchased from original owner in 2012. Many upgrades. All upgrades and repairs were done with the goal that we would keep this Airstream for many years and wanted it better than new. Eaz-Lift hitch and sway control bar included. We have all receipts including maintenance and repair done by original owner.
- UPGRADED CONVERTER TO 3 STAGE
- UPGRADED TIRES 2012 MICHELIN
- CUSTOM SUNBRELLA CUSHON COVERS
- CONVERTED TO TWIN BEDS
- UPGRADED CERAMIC TOILET
- UPGRADED RANGE HOOD FAN
- UPGRADED KIT AND BATH FAUCETS
- UPGRADED SHOWER HEAD OXYGENIC
- FULL OUTSIDE DEALR RESEAL 2013
- SKYLIGHT REPLACED WITH RESEAL
- UPGRADED MICROWAVE
- UPGRADED LED LIGHTING
- ADDED FANTASTIC VENT COVERS
Also selling our matching tow vehicle: 2010 Ford F150.
Also selling generators: Honda EU2000i and EU2000i Companion with RV Adapter and Parallel Cable Kit for safe power to air conditioner.
CHASSIS
7600 Lb. GVWR • 7600 Lb. Axle System • 5870#UBW • 1030#NCC • Styled Aluminum Wheels • Radial Black Wall Tires, LRD 15" • 12" Electric Drum Brakes • Stabilizer Jacks w/Pads (4) • Double Steel Step • Electric Hitch Jack • Spare Tire with Bracket.
EXTERIOR
Bright Aluminum Finish/Roof Finish-White • Polished Rear Bumper w/Storage • Safari Graphics w/Chrome Rub-Rail Inserts • Safari Medallion • License Plate Bracket • Grab Handle • LPG Bottle Cover • Enclosed/Insulated Underbelly • C.S & R.S. Awning Rail • 16' 4.5" Patio Awning • Solar Stone Guard • Main Door • Wrap Protectors.
WINDOWS & DOORS
S.P. Solar Gray Windows • Opaque Window in Door • Front Basement Access Door (Small) • Keyed Deadbolt at Entry Door • 1 Refrigerator Vent Door.
INTERIOR DECOR
Mini Blind Throughout except Panoramic Windows • Full Close-Out Drapes at Panoramic Windows • Real Wood/Steel Drawer Boxes • Finished Aluminum Interior Skin • Finished Aluminum Ceiling • Decorative Bath Vinyl • Entrance Mat • Laminated Countertops W/Contrasting Edge • Wooden Valances • Interior Grab Handle • Vinyl Flooring in Galley & Bath • Tropical Oak Laminate Interior.
BATH DECOR
Towel Bar (2) • Full Glass Shower Door • Hinged Bath Door • Fiberglass Shower w/Soap Dish • Mirrored Medicine Cabinet Above Sink • Ceramic Toilet • Stainless Steel Lavy Sink.
BEDROOM DECOR
Underbed storage • Foam Twin Ikea Mattresses w/Comforters • Storage Lockers over beds. Aluminum Mini Blinds and Blackout Privacy Shades.
GALLEY DECOR
Laminated Galley Top • Sink Cover • Stainless Steel Sink - Deep Round Bowl • Stainless Faucets • Aluminum Inserts on Refrigerator • 42" x 76" Dinette • Large Pantry Storage With Pull Out Microwave • Galley Skylight With Shade.
LOUNGE DECOR
Front Overhead Rooflocker w/Radio/DVD/CD/MP3 • 74" Front Deluxe Lounge • Storage Bins Below Lounge • Laminated Lift-Up Table • Decorative Throw Pillows Matching Upgraded Sunbrella Cushions.
APPLIANCES
Upgraded 15,000 BTU A/C w/Heat Pump & Comfort Control Center • 25,000 BTU Furnace w/Electronic Ignition • Three-Burner Cooktop w/Oven • Range Hood w/Vent & Light • Fantastic Fan Ceiling Vents (2) w/Rain Sensors and Matching MaxAir External Covers • Bath Exhaust Fan (12V) • 6.0 Cu. Ft. 2-Way Automatic Refrigerator • Probeless Tank Monitoring System • 6 Gallon Water Heater w/Electronic Ignition • Fire Extinguisher • Smoke, LPG & Carbon Monoxide Detector's.
ENTERTAINMENT & SOUND
Radio Antenna • AM/FM/CD/DVD Receiver • TV Antenna w/2 Outlets, Cable/Telephone Hook-Up • Satellite Prewire.
ELECTRICAL
Two Coach Batteries • 7-Way Cord Junction Box • 110 Volt/12Volt Power Center w/upgraded 3 stage 55 Amp Converter • 12 Volt ATC Fuses • LED and Incandescent Lighting • TV Jack w/12 Volt Outlet (2) • Phone Jack • 120 Volt Exterior Outlet • GFI Protection For Bath, Galley & Exterior Outlet • Patio Light • Exterior Light Pkg.: Dump Valve, Exterior Compartment & Area Light • Water Pump Switch at Galley • Electronic Battery Disconnect • Solar Prewire.
SYSTEMS
30 Lb Steel LPG Bottles (2) • Automatic 2-Stage Regulator • Oxygenics Shower Head w/Shut-Off • Water Heater By-Pass Kit • Lockable Water Fill • Water Pressure Regulator • Upgraded Ceramic Toilet • 39 Gallon Fresh Water Tank w/Drain Valve • 37 Gallon Black Water Tank • 39 Gallon Grey Water Tank • Safety Chain Hook, 11,700# Rating • Sewer Hose Storage Tube • 750# Hitch weight • Exterior Length - 28' • Exterior width - 8' 5 1/2" • Interior Width - 8' 1" • Exterior Height w/AC - 9- 7" • Interior Height - 6' 3.5" • Hitch Ball Height -17 3/4" • Heated Tank - Forc
You can contact us by filling in the form on the right hand column of the ad listing:
https://www.airstreamclassifieds.com/...27-washington/
