-   -   Awning dimensions (https://www.airforums.com/forums/f442/awning-dimensions-118344.html)
Rockyrigger 04-10-2014 04:53 AM
Awning dimensions
wonder if anyone can help. We are from the UK and have just bought a 1972 23' Safari which is currently on its way over here. We want to order a zipdee awning. When I contacted Zip dee they said we needed to measure the length, which obviously we cant do. Does anyone know what the width should be for this trailer?
Also interested to know the width of a rear window awning for the same AS
Inland RV Center, In 04-10-2014 06:42 AM
The correct length for Zip Dee is 12 feet 11 1/4 inches.
That is for a 13 foot awning.
When you install it, you will need to shorten the rear arm about 3 to 4 inches so that the mounting is immediately above the battery door.
The rear window awning is called an "047".
Rockyrigger 04-11-2014 03:21 AM
Thanks Andy that's really helpful. Appreciated.
