-   -   71 International Sovereign belly pan aluminum (https://www.airforums.com/forums/f4/71-international-sovereign-belly-pan-aluminum-112816.html)
cole3444 11-13-2013 05:16 AM
will 2024-0 clad 3032 aluminum work for belly pans. located some that is 48" X 144" locally at 50.00 a sheet? Is this good or bad. Is it ok to run the belly pan front to back in 48" widths riveted to the rails cut to length side to side?
Lance M 11-13-2013 06:25 AM
The price is good, for sure. I think you could make it work. O is very easily crinkled, kinked and dented. It is typically used to form a part or piece then tempered in an oven (heat treating). I'm sure it would be better than .020 3003 that was originally used in the 70s.
I prefer to use .025 6061 T6 for belly pans.
