-   Airstream Classifieds (https://www.airforums.com/forums/f534/)
-   -   2002 F450 Crew Cab DRW 4x4 Fontaine Classic Traveler (https://www.airforums.com/forums/f534/2002-f450-crew-cab-drw-4x4-fontaine-classic-traveler-112018.html)
DaGuru 10-26-2013 07:57 PM
Title:
I just posted a new ad on Airstream Classifieds.
(Price reduced to cover a set of new tires)
Super Rare Fontaine Classic Traveler Bed
2nd Owner, 168k miles
Purpose built to haul both the family and the big toys.
Many upgrades chosen to make this unique truck the way Ford should have built it in the first place.
-7.3L PSD
-AFe Stage II cold air intake
-Regulated Fuel return
-Solid HP Oil Cross-over
-R38 Ball-bearing Turbo installed @ 148k
-High Output Injectors installed @ 148k
-Fuel bowl delete
-AirDog fuel filtration system with pump
-Centric "power slot" cryogenically treated brake rotors @ 155k (can stop a 10K load without trailer breaks with ease)
-Custom Crown brake lines (5 line)
-Bilstein Shocks
-Custom Tuner (High Idle & Extreme) With this gearing, no other tunes needed...
-Autometer gauges: Fuel Pressure, Boost, EGT and Trans Temp
-Curt 20K Fifth Wheel Hitch
-Curt 10K bumper pull hitch
-Tekomsha P3 brake controller
-New transmission installed @ 140k
-All new brake calipers installed @ 145k
-Performance Torque Converter installed @ 154k
-4:11 Gears installed front/rear installed @ 158k
(13MPG - City/Highway)
-Drive shaft rebuilt/balanced @158k
-All front and rear driveline seals replaced @ 158k
Clean truck, title in hand. Previous owner dented the cab with his horse trailer.
After buying this truck to pull my 42' 5th Wheel, lots of money was put into this truck to make it stronger and even more reliable. Sold the RV and don't need this much truck anymore. This truck is setup to be a perfect tow vehicle for a full timer or hotshot driver. I'm not in a rush to sell, so only serious offers from educated buyers please. All work expertly done by Diesel Innovations.
Call/TXT Dennis @ 832_722-4914
Price is firm. Would consider trade for Jeep Wrangler 4x4 Unlimited or 25' or longer Vintage Airstream Travel Trailer. Must be in comparable or better condition.
Local Pickup, Cash or Local Bank Cashiers Check, No Shipping and No Brokers
You can contact us by filling in the form on the right hand column of the ad listing:
https://www.airstreamclassifieds.com/...ssic-traveler/
