-   -   '72 Overlander -- What is this meant for? (https://www.airforums.com/forums/f4/72-overlander-what-is-this-meant-for-109263.html)
tdyoungblood 09-03-2013 09:43 AM
I just purchased a 1972 Overlander about a month ago and in the midst of doing some clean-up and general maintenance, I noticed this metal strip on each side directly above the wheels. It looks like a "channel" that something would slide in to, but I have no idea what...was there a vinyl shade that would pull down over the wheels to protect from sun? Or maybe where wings could be mounted?
Also, the previous owner attempted to paint the trim but I see that blue piping is sold to fit in here. Does that piping stick to the Airstream channel? I don't see any grooves for it to fit in.
Any help would be appreciated.
Aviator 09-03-2013 10:09 AM
It is most likely for a wheel cover "curtain" They were usually made of the same fabric as the awnings and had a plastic rod sewn into them that slid into the channel and let the fabric hang over the wheels keeping the sun off of them.
I am not sure about the trim. Our 1970 was painted and our 1997 has a plastic insert.
ALANSD 09-03-2013 12:16 PM
the blue vinyl insert trim slides into the end of that channel and you pull it all the way through..
Supertwin1 09-12-2013 10:14 PM
channel around body
Hello. Did you ever find out what goes in the channel that goes around the body of your Overlander? I have a '72 Overlander and was wondering the same thing.
Larry
tdyoungblood 09-13-2013 11:26 AM
Rubrail Insert, Blue
I have not ordered it yet, but it looks to me like it is this stuff (insert, rubrail):
Welcome to Southwest Coaches - Airstream and RV Parts, Serving Los Angeles, Orange, Riverside, and San Bernardino Counties: California
I still can't figure out how it stays in the channel as my channels do not appear to have a groove to hold it. Maybe adhesive?
Supertwin1 09-14-2013 07:46 AM
Do not order it......it will not fit, nor is it designed to fit into the trim piece. I inquired and found out that Airstream used some plastic tape colored blue for the years prior to 1978. I was also told to paint the area where the tape was w/blue paint.
Lothlorian 09-14-2013 08:23 AM
I went to an auto store that makes vinyl strips for Business vehicles advertisments. took the measurements and they cut everything on a computer. It was so easy to put on and it still looks great. I have left over just incase I have to replace some. I will post pics later. My wife is ready to go and so I am out of here.
Lothlorian 09-14-2013 10:57 AM
If you scroll down this page you can see us with the installation of the vinyl strips
https://www.airforums.com/forums/f36/...n-38204-9.html
Brian
