-   -   late '50s early '60s floor channel (https://www.airforums.com/forums/f36/late-50s-early-60s-floor-channel-109247.html)
flyrc 09-02-2013 07:58 PM
I have to replace the floor channel on my 62 FC and want to know what alloy aluminum was used. I have measured it at about .023 thickness. Was it tempered or just 5052 type aluminum? Any help is appreciated.
rumrunner 09-02-2013 09:02 PM
A hard tempered aluminum like 2024 t3 will crack if you try to bend it like c channel. Use 5052 h3 in .032 or .040 and you will be happy with the results.
tim
JFerguson 09-05-2013 06:43 PM
Here is the replacement part: Floor Channel Bow - Narrow Body104463 [104463] - $58.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
putback 09-07-2013 06:23 PM
Common 5250 in .032 will form up in a common alum siding brake. The .040 will bend up in a good one. Comes out as original.
