-   -   Plastic white nose insert (https://www.airforums.com/forums/f39/plastic-white-nose-insert-106470.html)
Northlander 06-27-2013 07:05 AM
I got a bunch of the plastic trim that fits in the metal strip from out of doors mart. How do I install it. I did some by forcing, prying it in with a screwdriver. Not the easiest thing to do. I even left it out in the sun to soften it up, still too stiff to bend into the track. There must be an easier way.
mandolindave 06-27-2013 07:18 AM
I think I know what you are talking about
It slides in from either end. It has to be the same size as the original.
I need to replace mine at some point. I was thinking about formica strips that are used for edging
Inland RV Center, In 06-27-2013 07:37 AM
The replacement is larger than the original.
We shave ours down before shipping with a wood plane that trims the edges.
That makes it a breeze to slide in place.
Northlander 06-27-2013 07:38 AM
Bathroom
But I am doing the rear bath. So there is now way to slide it in from either end. I replaced all the blue plastic strip on the outside of the trailer, and that is how I did it, just slipped it , sprayed some silicone in the track and pulled it through.
This is turning out to be a pain. Literally, I have poked my fingers several times with the screwdriver forcing it in the track. Patience I guess.
wahoonc 06-27-2013 08:29 AM
Shave the edges as Andy suggests, I used a low angle block plane, then I soaked mine in hot water and used a thin flexible knife (like you would use to frost a cake) to pop the edges in.
Aaron:cool:
mandolindave 06-27-2013 10:07 AM
too late now
I think silicone is a no no around aluminum..Soapy water might be better
wahoonc 06-27-2013 12:11 PM
Silicone spray isn't a real problem, just silicone sealant...
Aaron :cool:
Aage 06-27-2013 12:21 PM
Aaron:cool:
Just so I'm really clear, Aaron, you are reducing the width, right?
Inland RV Center, In 06-27-2013 12:47 PM
Aage.
Wrong.
The width stays the same, but the thickness at the edges, is made smaller.
vchatelain 10-01-2013 07:23 PM
I need some of the plastic inserts. Where did you get it and what is it called?
V
