-   -   Sub-Floor Removal: Bolts Under Door Frame (https://www.airforums.com/forums/f36/sub-floor-removal-bolts-under-door-frame-105443.html)
crabbey1 06-02-2013 01:44 PM
4 Attachment(s)
Hey guys! My sub-floor replacement is going well, but I ran into a small issue. On my 1976 Argosy 22', the second section back of flooring has 3 bolts that hold it into the frame under the door frame. I cannot see the top of the bolts, I can only see the nuts under the frame from the bottom.
If I cut the nuts off the bolts, will i be able to punch them up through and release the small section of flooring left in the trailer? If I do that, how can I replace them in the new flooring? Any other thoughts suggestions?:huh:
Note: This is a shell on floor replacement. Also, I am doing this all without taking the bell skin off. Thanks.
cameront120 06-02-2013 02:00 PM
Do a search for 'elevator bolts' and you'll find all the information you could ever want. Good luck!
Tony S 06-02-2013 03:07 PM
Multi Tool by Fein
Will make your life much easier throughout your work
I never thought much about it. Thought it was a Toy for weekend warriors
(which is fine) but no it is an incredibly useful tool
Good Luck
Tony
crabbey1 06-02-2013 03:40 PM
Tony - I have been using a Dremel to cut the E-Bolts off. No biggie. I just wanted to make sure that these are ok to remove. Thanks for your help.
