-   -   Can I fix my awning permanantly (https://www.airforums.com/forums/f442/can-i-fix-my-awning-permanantly-103740.html)
wvabeer 04-20-2013 07:33 AM
Here are some pics of my boo boo. How would you fix this?
azflycaster 04-20-2013 07:52 AM
The suggested fix for holes is to patch it from the bottom with some matching material using silicone. Zipdee will send you the material for free if you give them a call. I am not sure that this will work for you because of the location of the tear. I would contact customer support at Zipdee and get their advice.
wvabeer 04-20-2013 07:58 AM
It isn't a zip dee its an A&E systems elite 9000
azflycaster 04-20-2013 08:37 AM
The same principles should apply to any brand of awning since this is a fabric issue.
wvabeer 04-20-2013 08:50 AM
I called A&E and they told me to buy a new awning. When I had a zip dee they sent me a roller and a piece of fabric. I thought this was made of different stuff. I used tear mender and a piece of the zip dee fabric and glued a patch over the rip on the zip dee . Can I do the same with this fabric?
bonginator 04-20-2013 08:57 AM
If you don't get any good confident suggestions here or thought the manufacturer, I might try either a convertible top manufacturer or a tent manufacturer as an alternative since they both produce fabric products that have to withstand pressure and wind... Just a suggestion.
azflycaster 04-20-2013 09:14 AM
I made a repair on my Zipdee using the method recomended by them. The fabric on mine was made by Sumbrella, I do not know what yours is.
masseyfarm 04-20-2013 09:46 AM
To make a temporary repair so that it did not travel more, why not stick a chunk of Eternabond on the bottom side. It can always be covered with something else later to match the color???? Just a suggestion as I have not had the pleasure. :blush:
Dave
heavyd 04-20-2013 10:01 AM
There are two or 3 kinds of awning repair tapes available as well. A company called INCOM makes some that is clear and works pretty well on some tears. Or the patch method you mentioned might work as well.
wvabeer 04-21-2013 06:18 AM
I am going to try the patch with a piece of outdoor fabric and tear mender today pictures to come
Airtandem 04-21-2013 07:45 AM
get some of that clear plastic material they use to repair swimming pools, and patch from the under side as well as the top side
wvabeer 04-21-2013 09:05 AM
here is the patch job
wvabeer 04-21-2013 07:07 PM
All dried up, looks better than a rip. LOL ;)
