-   Clearcoat, Exterior Paint & Trim (https://www.airforums.com/forums/f474/)
-   -   Blue Accent lines (https://www.airforums.com/forums/f474/blue-accent-lines-10220.html)
boltos 03-24-2004 08:29 AM
Blue Accent lines
Could someone clarify to me if the blue accent lines on my 1970 Safari are painted on or if they were originally an applied moulding?
I've seen a sort of blue vinyl tape at the Jackson Center store, and assumed that's what that was for, but oher areas like around the tail lights could only have been paint.
Thanks in advance
smily 03-24-2004 08:46 AM
Of paint and stripes
Typically, the only paint on an Airstream is the lower bannana wrap section and sometimes the white roofs.
But the blue stripes were decals or "stickers"
On many AS's there can be what is referred to as rubrails and beltlines, these were typically an aluminum extrusion that was riveted to the sides of the trailers. The extrusion has a channel in the middle. The channel was filled with a plastic or vinyl moulding. You can still get some of the mouldings form most Airstream dealers, Ebay, and I have even seen it at SOB dealers.
Some owners have replaced the stripes, (declas) with painted on stripes. I have even seen people paint the channel of the extrusion rather than re-insert replacement moulding.
Smily
pepper48 03-24-2004 11:41 AM
Per Andy, vinyl was not used until 1974. Prior to 1974 both the rubrail and beltlines had painted centers.
