-   -   Air compression (https://www.airforums.com/forums/f311/air-compression-101740.html)
ericjan2 02-24-2013 07:36 PM
Air compression
I have a 290 motor home. When I turn on the ignition key the air compressor kicks on and runs, and runs, and runs! It never stops. It's putting out air but not filling the rear air bags. I have constant pressure in the bags so I know it's not loosing pressure there. The lines must be loosing it because isn't the compressor supposed to stop running automatically once it senses the correct pressure? Does anyone know how to test the auto shut off switch and where I can purchase a replacement air line system for an 87 Motor home? Maybe Inland RV or Firestone??? Any help is appreciated.
Gene 02-24-2013 08:03 PM
I think there was another thread recently about the same or similar problem—try thr search function and you may find answers.
Gene
ericjan2 02-24-2013 10:32 PM
Tried that extensively but couldn't find anything!
idroba 02-24-2013 10:46 PM
If it is like my '83, 310 was plumbed for air it worked this way: The compressor had a line from it went directly to the air tank. From the air tank a second line went back to the pressure switch. In the line to from the compressor to the tank there was a check valve. In my rig, that check valve stuck shut, and would not let air from the compressor into the tank, so the pressure would not build up and allow the switch to shut off. It took me a long time to figure out about the check valve, and it's problem, as well as where it was.
I replaced the check valve on mine and all my air suspension problems were solved.
The other thing that could be happening is that the compressor is simply not producing pressure due to being worn out, or a broken fitting or some problem of that sort. Since the pressure switch on mine was not in the compressor line, but in a separate line from the tank, once it switches on, It would not go off until the pressure was brought up to the cut off level. So, worn out compressor, leaking line somewhere between the compressor and the tank, or bad check valve .
Those are my best guesses at this point.
Kota 02-25-2013 10:08 AM
Could be a check valve in the compressor too.
Gene 02-25-2013 12:22 PM
Here's a thread, but not knowing about this, it may or may not be helpful. The OP started out looking for a separate 12 v. compressor, but the discussion turned to a MH internal compressor: https://www.airforums.com/forums/f311...ors-99848.html
Gene
ericjan2 03-13-2013 09:21 AM
Do you recall where you purchased the valve? Also, I'd like to start the process of elimination. I'll change out the 1/4 inch air hoses first. Then pump up the system and wait to see if the pressure bleeds off. Any ideas if anyone out there sells replacement line kits?
Waipio Rim 03-13-2013 11:43 AM
Our air bags were leaking down overnight, so I bought a replacement check valve from Inland RV. Could not find a valve in the system to replace, so I had to adapt it to the line coming out of the compressor. Holds air much better now.
Smartstream 03-13-2013 11:47 AM
Try these guys. VIAIR Corporation - 12 & 24 Volt Air Compressors They are not too far from you in Irvine.
