Old 05-31-2023, 07:32 PM   #121
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Finished up two tasks I started months/years ago, the curb side awning and a modification to our banquette table.
I started buying pieces to make the awning several years ago. The awning uprights I bought from a damaged freight seller (scratches in the paint) and the awning with roller from a local person. He bought the awning and never installed before he sold the rv. A few odds and ends from rv sources. The uprights are for a newer model than my 58, which meant they were too tall, but they were the right contour. Shortened both ends and remade the holes/slots as needed.
Name:	Modified awning arm upper.jpg
ID:	432557 Click image for larger version
Name:	Modified awning arm.jpg
I bolted the lower mount through my perimeter frame steel tube and double nutted so they are solid. The upper mount is with four 1/4" rivnuts.
Name:	Lower awning support bolted thru perimeter frame.jpg
I stripped the paint/powder coat off the outer arms and started the polishing process. I'll finish it later now that the awning's installed so less chance of messing up the final polish.
Name:	awning installed.jpg
I was never happy with the table. You have to make it wide enough to be supported by the edge of the seats, which makes it hard to slide in and out of the seats. I thought I had solved that with the German made pedestal that allows you to slide side to side, front to back, and even angled. Tried it out for a few seasons and was not satisfied. Started looking at ways to narrow the table by having folding leafs. Finally found a solution I liked that did not appear to affect the area under the table too much (Can't make the folding mechanism too thick or it affects leg room. These are spring loaded hinges that can support the leaf when you lean on it and still support you when made into a bed. I also added a plate to the top of the pedestal to mount the height locking handle. Before I had it mounted to the bottom of the table. That made it hard to use the handle and sliding the table top on the pedestal was making the cable kink in certain positions.
Name:	Table leaf hinge.jpg
ID:	432562 Click image for larger version
Name:	Table leaf folded and height lock handle.jpg
Also like that we can fold one side or both depending on the need.
Name:	table one leaf folded.jpg
ID:	432560 Click image for larger version
Name:	Table folded up.jpg
I thought about making the leaves deeper, to make more of a coffee table, but the pedestal attachment frame (metal) was too wide for that.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 06-01-2023, 06:32 PM   #122
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Great minds think alike. We had the same folding leaf idea for our dinette table. However, our system is much less sophisticated than yours. Our pedestal allows the table to rotate which makes entry and exit from the table easier. And we can lower the folded table to be more of a coffee table instead of a dinning table.
Yours looks a lot better. Oh well, I'll keep plugging away.
David
Name:	1602 Table Up 2-800x600.jpg
ID:	432595   Click image for larger version
Name:	1602 Table Mid Folded-800x600.jpg
Name:	1602 Table Sleep Position-800x600.jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 06-01-2023, 09:49 PM   #123
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Like! Bet you could make a jigsaw puzzle on the center section and secure it overnight by folding the leaves up as a cover. Frustrate your cat or dog.
Old 06-02-2023, 06:32 AM   #124
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
Masterpiece
Harold.
I have long admired your work and level of craftsmanship that have gone into your Airstream. But I just finished rereading your thread from start to finish..
What an amazing job you did, Harold!!
And your documentation skills, the way you have photographed and written your blog, deserve mention as well.
Bill
wcronin4 is offline   Reply With Quote
Old 06-02-2023, 09:09 AM   #125
57Vintage's Avatar
1958 26' Overlander
Images: 22
Thanks David & Bill
Now that most of the bugs are worked out and we've had a chance to use the trailer the last couple of years, I tend to let these changes slide. I have a couple more a do plan on doing this summer, but it will have to wait until we get back from the International Rally.
Any chance any of you are going to the International Rally? We're caravanning in with the Oregon club and will be where ever they put the Region 10 caravanners.
Harold
Harold & Rebecca
Our thread:
Old 06-02-2023, 12:44 PM   #126
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Harold: Yes, the DW and I are going to the International Rally the last week in June. We are taking her 86 Limited 34' triple axle and requested parking in the "vintage Airstream" area. So maybe our paths will cross. Our BRN is 8607.
David
Old 06-02-2023, 09:48 PM   #127
57Vintage's Avatar
1958 26' Overlander
Images: 22
David not sure where we will be. I opted out of parking in the VAC area because Region 10 is caravanning into the event with 7 or 8 caravans, which I'm participating in, from various states/provinces and I expect that will be a drawn out process and trying to exit that process will just make it worst. I'll let everyone know where we are once we set up.
Harold
Harold & Rebecca
Our thread:
Old 06-03-2023, 06:23 PM   #128
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Okay, safe travels.
I think I told you I nearly purchased a 1959 Overlander many years ago. It was the first vintage Airstream I looked at, and it was in pretty good shape. Still being used every summer. I sure couldn't make it as beautiful as yours.
Here are a couple few photos of the thing.
I ended up with a 1966 Trade Wind 24'. It wasn't in as good of shape, but I was attracted to the dual axles.
David
Name:	1309 Door Side (Small).JPG
ID:	432723   Click image for larger version
Name:	1309 Gaucho (Small).JPG
Name:	1309 Princess Stove-800x600.JPG
ID:	432725   Click image for larger version
Name:	1309 Twin Beds-800x600.JPG
Hello all, Our 'Valentine' is the love of our life, and fast becoming our 24/7 addict errol108 Member Introductions 6 10-14-2019 07:04 PM
1957 Overlander on European Ebay Pschoerrn Off Topic Forum 11 07-09-2009 04:41 AM
1957 Overlander towing after 12 years sitting on the same site. HELP! SUEHOWIE Tires 25 10-21-2008 10:36 PM
wheel/tire recommend for single ax. overlander (1957) p.dow Tires 23 10-01-2008 01:59 PM
1957 Airtream Overlander Newbie kim McCumber Member Introductions 7 09-29-2008 07:47 PM
