10-26-2010, 02:17 PM
2006 22' International CCD
1957 26' Overlander
Plymouth
Moving the Entry Door
What am I up against?
I have a 1957 Overlander. It is in need of some attention, lots of attention.
When and if I ever really get finished I would like a trailer that has all the features I am looking for. A queen sized bed is one of thoes features. By moving the door one ribspace I can fit one in. I would be moving the door towards the middle of the trailer. The bed would be in the front and would go side to side.
What are your thoughts?
10-26-2010, 02:35 PM
Common Sense
The first thing that comes to my mind is you will have to replace all of the aluminum on that side of the trailer, or have a patch where the door was originally.
Regards,
Steve
10-26-2010, 02:45 PM
1957 26' Overlander
Plymouth
That will be the easy part. I will be replacing enough metal that a little more wont hurt. If I start making changes I want to do it right
10-26-2010, 02:48 PM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
How much are you going to be able to move the door? How much area do you have before you get to the inner wheel well?
Avion C11
1959 Flying Cloud 1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
10-26-2010, 02:50 PM
asbury park
, New Jersey
wow. that sounds like quite a project. if you do it, please document for the rest of us. why cant you put the queen bed on the other side of the trailer, the back? then give it a center bath?
10-26-2010, 02:54 PM
1957 26' Overlander
Plymouth
I will be moving the door about 24" which will put me about 4" away from the wheel well. I want to move it to the last full rib before the wheel well
10-26-2010, 02:59 PM
1957 26' Overlander
Plymouth
Cause Im nuts. We have a 22' CCD with the bed across the front and we love it. I build and remodel custom homes so I cant leave anything alone and we love the big rear bath. Its roomy, we currently have a wet bath in the 22'
10-26-2010, 03:01 PM
2008 27' Classic FB
fairview
, New Mexico
I thought about the steps but if the floor and steps are in the condition of the ones in my 59 Flying Cloud that shouldn't be a problem. On mine the floor is rotted and the steps are rusted away. I don't see why you can't do your mods.
Avion C11
1973 Safari
1983 34 ft Limited
10-26-2010, 03:03 PM
1957 26' Overlander
Plymouth
Before this is over it will be a shell off rebuild. The floor is rotten and Im unsure what the frame looks like
11-02-2010, 07:33 AM
1954 25' Cruiser
Cruisin
, Wisconsin
Hey Brad, That sounds like an interesting idea, I like it. The only thing that I could see is the shell may have more stress on it closer to the center? I have read other threads about stress cracks above the door in its present location but maybe that is caused by frame problems?
Good luck,Doug
11-02-2010, 07:07 PM
2022 25' International
Savage
Good luck,Doug
Our '64 Safari is prone to a stress crack near the door frame by the front curbside window. I believe it happened to Viking and others.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
03-10-2011, 08:35 PM
1957 26' Overlander
Plymouth
I started to move the door. It went from the front all the way to the rear. Im waiting on new hinges to complete it.
Once I get it mounted and swinging the way I would like I will start filling the holes.
03-11-2011, 07:01 PM
1954 25' Cruiser
Marshfield
, Massachusetts
Brad I like it. I have a '54 crusier and I want to make the area at the front a large living room but the door kind of limits what you can do. I'm not sure I'm up to moving it but I really want to follow what you're doing here so please document with lots of pics. Thanks
03-11-2011, 07:38 PM
1957 26' Overlander
Plymouth
Hi Don
I will do my best. If you want to see what else is happening with the trailer look at the thread titled " I found the leak" After rebuilding both endcaps moving the door didnt seem as hard as I thought it would be
03-11-2011, 07:59 PM
1958 26' Overlander
Lander
, Wyoming
Brad That site should work. That is the exact position of the second door on my 58 double door cruiser. Ed
03-16-2011, 05:26 PM
1957 26' Overlander
Plymouth
Yesterday I received my new door hinges and got them mounted. The door is now installed in the rear of my trailer. It was almost anti-climatic I was hoping for a band to play or some mystery to be answered. Oh well!
I took the outside skin off so I could mount the new hinges. I will leave the inside skin on until I have the new outside skin clecoed in place. The door seems to bee keeping its shape just fine.
03-16-2011, 05:47 PM
1958 26' Overlander
Lander
, Wyoming
Brad Any thoughts to adding an extra layer of aluminum inside the outer skin where the hinges attach. I bent some heavier aluminum sheet. I think 060 and riveted it from one rib to the next at the levels where the hinges attach to the body. Kind of like a very wide C channel with 1.5 in legs. This gives a lot of extra support to where the hinges meet the body. Just a thought. Glad the door move has gone well. Ed
03-16-2011, 05:56 PM
1957 26' Overlander
Plymouth
Originally Posted by n2batr
Brad Any thoughts to adding an extra layer of aluminum inside the outer skin where the hinges attach. Ed
Yes. The outside row of rivets on the hinge leaf fall over a rib. I am planning on riveting some 1-1/4" L channel to the rib for the other set of rivets to go through
03-16-2011, 06:07 PM
1958 26' Overlander
Lander
, Wyoming
Excellent. Might as well add some strength. All the best Ed
03-16-2011, 07:36 PM
1957 26' Overlander
Saint Augustine
Photos will answer this, but with the curve of the "butt" of the AS, how does the door look when open? Does it lay back against anything or will it just keep closed?
Rae
via~ AIR Forums App.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
