Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1954 - 1959 Overlander
Old 02-01-2013, 12:26 PM   #181
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I meant the windows I have are the 24 and 30 inch wide ones.
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-01-2013, 12:35 PM   #182
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
It looks like all the windows on the caravanners are the same size from what I can tell. My hunt continues. Thanks for looking.
I'm working on having some made.
Thanks again and your trailers looking great!
desertair27 is offline   Reply With Quote
Old 02-01-2013, 03:46 PM   #183
BradS's Avatar
1957 26' Overlander
Images: 14
I guess I need to look at caravanners. With all that glass they must be real nice.
I had another good day working on Holly. I drilled out the last of the rivets and positioned the trailer for lifting. Much to my surprise when I leveled the trailer my door no longer latched. I have a few hours into the door and I should have known better. The trailer was not level when I set it. Nothing a nudge, twist and pull didnt correct.
I think Tim is coming down tomorrow. Ill start the hidden rivet hunt and see how far I get
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-02-2013, 06:11 AM   #184
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
That looks and sounds like a lot of fun, I need to try and get over there!
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 02-02-2013, 06:58 AM   #185
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Caravanner windows.
Hey Brad
If you like lots of windows the Caravanners are very nice.
Good luck on your shell lift off!
Mike
Old 02-02-2013, 07:57 PM   #186
BradS's Avatar
1957 26' Overlander
Images: 14
Hi Mike That has to be the longest drip cap, over the window ,that I have ever seen. Im not sure I would know what to do with all thoes windows. Of the 9 original windows in Holly only one is where it started.
Well the body is still sitting on the frame. I need take down a couple of 4x4's to hang the body from.
The weather is supposed to take a turn for the better. That means back to work so progress will slow again. Oh well Im much closer to lifting the body now
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-07-2013, 12:52 PM   #187
BradS's Avatar
1957 26' Overlander
Images: 14
I got laid off yesterday!
ID:	178452So today I went to Holly for lift off!!!!!!!!!! I wasnt sure this day would come. Each time I get laid off I react in some unexpected way. When I got laid off from a purchasing job I took up exercise. This Time I popped the top.
Now I will start reading again.I have a lot to learn. Anyone with opinions , please share. Thank you in advance. Ill strip the old floor off, see what I have , do some funky voodoo stuff and see where it goes.
Enjoy your day
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-07-2013, 12:56 PM   #188
BradS's Avatar
1957 26' Overlander
Images: 14
And thank you Doug and Tim
Because of you two guys Holly came into my life and I hope to share this trailer with Jennifer for a long time to come.
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-07-2013, 08:10 PM   #189
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Glad you had some fun today Brad! Only wish I could have been there with you!
You are right guy for the job, glad you are enjoying your project, Holly has come a long way already!
What we do for shiny aluminum??
Keep up the great work!
Doug
Old 02-07-2013, 09:59 PM   #190
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Congrats on your shell lift off,some day I'll be where you're at I hope!
Too bad about the lay off but you know the saying, one doors closes and another opens! Enjoy your trailer.
Mike
Old 02-16-2013, 01:41 PM   #191
BradS's Avatar
1957 26' Overlander
Images: 14
I finally made it down to the trailer today. It seems like when I'm not working I'm busier than when I am. I always think that I'll have soooo much spare time. Once again that's not the case
I got the last of the plywood off the frame today. I have more cleaning to do but the bulk of it is gone. I was surprised how little rotten wood there actually was. Some of the fiberglass insulation actually looked good. Most of the belly pan is intact so ill have good templates for the new one. I hope. Time to start looking at wheels, tires, axels, steps, tanks,etc,etc
WBCCI 10289
TAC MN-69
AIR 11240
Old 04-15-2013, 06:59 AM   #192
BradS's Avatar
1957 26' Overlander
Images: 14
Yesterday morning we left home , Minneapolis, and it was 28 degrees and sleeting. We drove as far as Macon Missouri and found 75 degrees and sunshine. I'm glad we have a trailer to use while I work on Holly. We spent last night at Long Branch Lake State Park . Beautiful park, and the lake isn't frozen. We hope winter will be gone when we get back. Today we head for Hermann Missouri about 90 miles away. The map and several other sources say its the Rhineland of America. Well , breakfast is ready, enjoy your day
WBCCI 10289
TAC MN-69
AIR 11240
Old 04-15-2013, 09:05 AM   #193
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Oh, you brat! You left us here??!!!!! Stay away at least 2 weeks according to the current weather forcast - the snow MIGHT be melted by then. Our Navy son and family are moving to NY state from Hawaii in early May. I've told them to expect snow when they get here.....
Enjoy your trip!
Kay
Kay
Old 04-15-2013, 01:19 PM   #194
BradS's Avatar
1957 26' Overlander
Images: 14
Thanks Kay
We had forgotten how nice it was to be away from winter. It sure is nice to travel. What a change for your son and his family. At least now you can take your trailer when you go to visit him, assuming winter ends
WBCCI 10289
TAC MN-69
AIR 11240
Old 04-15-2013, 02:01 PM   #195
Minno's Avatar
1972 31' Sovereign
Yes, we're looking forward to visiting them more often, weather permitting. Hawaii is sooooo far away! I'm frustrated right now because I can't sanitize their water system in their trailer (we're babysitting) or wash it yet for them. Oh well, back to quilting for a little longer.
Kay
Old 07-02-2013, 06:35 PM   #196
BradS's Avatar
1957 26' Overlander
Images: 14
Here are a couple photos of Hollys door now that the lock is mounted
ID:	190023   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 07-03-2013, 06:59 AM   #197
Sum75's Avatar
1957 26' Overlander
Los Angeles , California
That door looks great! I can't wait to (someday) install my handle on my 57 Overlander. Sometimes it's the little things that make the biggest impact :-)
Sum75 is offline   Reply With Quote
Old 07-08-2013, 06:45 PM   #198
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
Looks fabulous!!
Airstreamin' dreamin'.
Follow our blog! https://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 09-20-2014, 04:30 PM   #199
BradS's Avatar
1957 26' Overlander
Images: 14
Started on the floor
For the past few weeks I have been getting down to the trailer and working on the floor. Im using 5/8" fir underlayment and coating both sides with epoxy.
After a few phone calls I was able to get new axels ordered from Colin Hyde. He was very generous with his time and shared a lot of great ideas with me .
WBCCI 10289
TAC MN-69
AIR 11240
Old 09-29-2014, 07:13 AM   #200
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Great to see your progress Brad! You will have her done in no time now, probably a little more comfortable working on her this time of year instead of when the snow is flying!
1957 overlander, leaks, replace
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
I think I found My TV augier Tow Vehicles 29 02-06-2009 05:52 PM
Finally found the leak! OregonArgy Repairing/Replacing Floor &/or Frame 4 04-04-2008 10:59 PM
'02 Bambi Leak - Found it! RangerJay 1997 - 2004 Bambi 0 03-31-2007 10:53 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
