07-04-2011, 01:52 PM
#21
Central
, Mississippi
Looking GREAT!
07-04-2011, 03:24 PM
#22
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville
, Wisconsin
gorgeous! That original fridge doesnt need a new home does it? :-)
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
07-05-2011, 03:35 AM
#23
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
it sure doesn’t . The Fridge was one of the few parts, that i can actually re-use.
07-05-2011, 08:18 AM
#24
1975 Argosy 26
1963 24' Tradewind
Seattle
I'm curious about what kind of welder you have? Have you welded for awhile? Marc
07-05-2011, 08:41 AM
#25
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
Wow.. looks really good!
07-05-2011, 11:07 AM
#26
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
i use a Lincoln, 110V gas less mig welder. i never really learned welding, and the last project i welded was about 10 years ago.
But i have to say, im not very happy with the gas less. Welding Mig with a Gas welder gives you a cleaner surface. But overall, once i have gotten used to the welding machine, it went alright.
Thanks guys for the compliments
07-05-2011, 07:36 PM
#27
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
Looks so nice . . .
Did you do the work on the axle? If yes, where do you get all the parts and pieces (bushings, bolts, u-bolts . . .)?
I also want to entertain other interior paint ideas. I like zolatone but I'm just sort of burned out on buying tools and learning new skills (for the moment) . . .
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
07-05-2011, 08:04 PM
#28
Powder Springs
, Georgia
Zolatone
It's not as bad as you might think! Try it!
~Lynnetta
07-05-2011, 08:20 PM
#29
1963 22' Safari
2020 27' Globetrotter
State of
I would agree, if you simply want some other type of finish go for it, but if you are avoiding zolatone for technical reasons it is really easy to apply, more forgiving than virtually any other paint surface.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
07-06-2011, 03:31 AM
#30
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
i am looking for a different product than zolatone if possible. its a little pricey, and i wanted to just go and spray it once and be done with it.
About my axle:
i rebuilt it myself.. the U-bolts i got from Napa, the rest of the bolts from Fastenal and the bushings from a local trailer place. I took all the spring packages apart, cleaned of the rust , primed and painted... easy :-)
08-20-2011, 09:51 AM
#31
hampden
, Massachusetts
awestruck in MA...
Wow is all I ca say! I am looking at a '59 Overlander and it is in pretty good shape.... Skin is beautiful....not a ding or scratch. Same with underpan. Only detail is that it has sat for probably 40 years. Still convincing the couple to part with it
I know it needs a new coupler/jack and tires/rims. Rest of the frame seemed to have only surface rust. Thinking I can get in there with a wire brush and scrape away for an afternoon. Ideally, would remove the frame as you did, but just don't think that will happen. Floor seems solid. Filled with junk and several wasp nests! Oh, and original appliances
As for tires/rims, what should be used? The currently wheels/tires are huge and look like they were for off roading!!
Amanda
02-12-2012, 07:57 AM
#32
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
Finally - the resurrection continues...
After a very long break ( Life came in between me and the Airstream ) I finally have some time to continue.
I bought my flooring, insulation, bolts and a bunch of small Parts.
Great Thanks to Vintage Trailer Supply for their excellent service and supplying us with the right materials.
The first challenge was to try to figure out the floor, since i had no templates . The shell was not 100% leveled, and not straight anymore.
I bolted wood on the outside to give me a straight side , checked with a laser pointer front to back and i re-alligned (pushed) the back and front to be centered. Once this was accomplished I traced the front and back of the shell and verified the distance between front and back section.
02-12-2012, 08:07 AM
#33
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
After cutting the Floor, i noticed, the curvature left to right is a bid off.. but all my measurements , (center, distance to frames) is correct ? But since the front and back floor section fits 100% and i have a distance between both section , which i measured to be within 1/16” left and right, i am pretty confident, the shell will fit.
The whole floor was then laid out on the frame and i started to figure out, how to get the seam on the center of the frame. Once this was accomplished, i turned the wood upside down and epoxy coated the floor.
Even though the Temperatures are today into freezing , i am getting ready to go back outside, bolt on the floor and figure out , how to flip the frame, so i can install the insulation and the belly pan.
After that i will work on my new C- Channel .Hopefully by next weekend I will be able to set the shell (if it fits )
02-12-2012, 04:25 PM
#34
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
Well, I made it. The Floor is bolted down. Out of my whole order of elevator bolts, i have one (1) left
Next weekend i will work on the insulation and hopefully the Belly Pan, as well as the C- Channel. Just wish i would be able to turn the frame upside down..
02-13-2012, 08:36 AM
#35
Central
, Mississippi
Originally Posted by submariner
Well, I made it. The Floor is bolted down... Just wish i would be able to turn the frame upside down..
If you can beg, borrow, rent or steal two engine hoists it's pretty easy to flip over the frame...I highly recommend it
Yes, it was cold and windy...we were camped over in Ocean Springs and even the Snow Birds from Canada were fussing about the weather!
02-17-2012, 07:40 AM
#36
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
I managed it to install all new C-channel. Turned out pretty good i think. .. Just hope, the shell will fit
This weekend i will install all the insulation and hopefully my new Belly Pan. I picked up 5 sheets of 0.032 in 4’x10’ for 46.- each.. Not too bad.
02-17-2012, 03:37 PM
#37
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
Insulation done... 3/4” styrofoam with 3/4” strips above it All i got to do is tape the seams.
Tomorrow i will get started on the new Belly Pan
02-18-2012, 11:34 AM
#38
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
got the taping of the insulation finished.
Now i can start with the belly pan....
02-18-2012, 12:36 PM
#39
1959 17' Pacer
Long Beach
Wow, you really resumed your project on a sprint. Trying to make up for lost time?
It's looking great!
02-19-2012, 12:48 PM
#40
1976 Argosy 26
Simsbury
, Connecticut
Where did you buy the aluminum belly pan sheets? From what I've seen that looks like a great price!
Thanks, Gary.
