Old 11-12-2006, 07:05 AM   #21
1957 30' Sovereign of the Road
Stanardsville , Virginia
Originally Posted by robandzoe
What is the rope up on the awniing rail from front to rear? It appears that there is evidence of the Air pressure line from the filler neck to the top of the rear tank... but no Air compressor. They appear to be aluminum. They need to be pulled to check for holes on the underside.
That's the temp wiring for the lights, and yes the living room is huge.
asta2 is offline   Reply With Quote
Old 11-12-2006, 07:05 AM   #22
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Rob, I think they had to run wires for the temporary taillights, that is probably the wires for them. It's too bad I didn't know you needed a tub, I tossed one when I moved two months ago, as I had no room in the new garage.
Old 11-12-2006, 07:11 AM   #23
Solidarity with Tim!
BTW Rob, that would be a 2 5/16" collar up front we had put on. (we were listening to the VAP on the road home, heard you and Colin giving him a hard time...)
Old 11-12-2006, 04:18 PM   #24
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
That looks like a California model, with the toilet on that side.. my toilet was on the other side. What do you think Brad? My SOTR has the toilet on the curb side. As far as the tanks, my SOTR had one under the front gaucho - not too. Was there a air compressor near them... this was the pressure system, that is why they are round - for pressure reasons - at least that is what I believe. Did it have both bunks? Shop-vac, I think you should just take a pressure washer to it.. that is what some people do. How is the floor? What type of door lock/handle is on it? Did just the glass break or whole window? Hopefully they did not cut the window frame up front like they did on mine when they put the AC in. That was $$$ to fix! Just remember, there are few of these big old girls left! I am looking for a street side tub for a 58 Overlander - yours is curbside right?
Rob
With the "O" in front of the serial number, I think it is an Ohio trailer, it has the same serial number plate as my 1954 Ohio Liner.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
wkerfoot is online now   Reply With Quote
Old 11-12-2006, 05:06 PM   #25
Have I mentioned how straight my skin is?
But it appears the floor will need to be completely replaced, which doesn't give me much hope for how the frame's going to look -- glad I wasn't planning on using it for any Fall rallies (or Christmas or Spring)...
Old 11-12-2006, 05:10 PM   #26
1993 21' Sovereign
Maybe you can finance the rehab by cooking meth. After all, it's already set up for it...
Old 11-12-2006, 05:22 PM   #27
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Asta2,
Although I have to completely replace the floor, the only frame damage is some of the outriggers, the frame channel and crossmembers are fine. Perhaps you will be as lucky.
Bill
Old 11-12-2006, 05:23 PM   #28
Moving forward
As we're doing the rebuild I'm going to have my Son doing the photo work and posting on a web page as a homeschool project, and to free up this site. I'll link the page as I provide updates on progress.
We got the front end cleared out this afternoon, except for the water tanks and associated junk, stopped before working on the beds - also pulled out the household toilet in the rear. Lots of delaminated wood either resurfaced with early 70's paneling, or covered in multiple coats of paint. Only things we saved were the drawers, oven, the countertop and sinks, but the sink fixtures have been replace with a standard household one at some point so I think its a wash also - we'll use the pictures to see if anyone here has a vote.
What a mess, bed of my truck is full of stuff headed to the dump. Going to eat dinner now, back in a while...
Sean
Old 11-12-2006, 05:24 PM   #29
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Good luck.
Spring or Summer... better get busy!! You should start seeing some things happening to the SOTR on our end too!
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
https://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - https://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 11-12-2006, 06:21 PM   #30
1993 21' Sovereign
Sean
I think regular apartment-sized appliances and plumbing were used "back in the day", so the sink, even if replaced, may be almost the same as the original.
Old 11-12-2006, 06:43 PM   #31
Thanks Terry,
I think you're right it doesn't look like anything special. I'm really only holding it to see if anyone else wants it, as it looks like we are going to start fresh on the interior.
A long road we have just begun...
Sean
Old 11-12-2006, 06:52 PM   #32
1993 21' Sovereign
Sean
If the sink looks like this (I couldn't find a photo you had of it), it is OEM, or so close as to make no difference:
Name:	1959 Airstream 004.jpg
Old 11-12-2006, 06:54 PM   #33
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Terry,
Is that sink enamel over steel?
Bill
Old 11-12-2006, 06:55 PM   #34
1993 21' Sovereign
Originally Posted by wkerfoot
Terry,
Bill
Yes it is. The photo is from a 59 Ambassador, the one in our Overlander is identical, but I can't find a good pic.
Old 11-12-2006, 07:02 PM   #35
Sink
I'll post a photo tomorrow - I think this one is enamel over steel, but it is actually two sinks mounted next to one another, in one large cut off of the countertop, and separated by a strip of metal. I'm sure the faucet is not original.
Old 11-12-2006, 09:55 PM   #36
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Yes! Finally someone on my side! I need all the allies I can get
-Tim
theVAP - Airstream Podcast
Old 11-13-2006, 08:28 AM   #37
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I thought I had read somewhere about the hazzards of "meth"...the process of making it can ruin a house. dangerous chemicals get absorbed into the walls and so forth, making the place uninhabitable. I don't want to be perpetuating urban myths...but I'd look into this. I'm not exactly sure where to start. maybe some drug-cops? anyway, find out. you might not want to be breathing the air in there. It might require a full-monty to get rid of anything in there that could have possibly absorbed any of this stuff...pull the walls, new insulation, new floor (which you were already planning).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-13-2006, 08:58 AM   #38
Gee thanks Chuck More good news...
Old 11-13-2006, 09:13 AM   #39
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I agree with Chuck...check it out. I know they busted a mobile meth lab not too far from my house here a while back and they had the hazmat guys in there in their moonsuits. In this case it was in a cargo trailer. They loaded the trailer up on a roll back, tarped it and hauled off when the hazmat guys got done with it.
Aaron
WBCCI #XXXX AIR #2495
Old 11-13-2006, 09:21 AM   #40
Aaron
Here you go - I guess we're truely gutting it and starting fresh...
http://www.stateline.org/live/detail...ntentId=147134
1957 sovereign
'58 Sovereign of the Road Trekking North robandzoe 1955 - 1959 Sovereign 34 12-27-2007 12:35 PM
"The Tube's" Adventure Begins myboyburt Cleaning, Stripping & Polishing 44 07-11-2006 02:50 PM
58 Overlander interior skin dan_lemire General Interior Topics 5 02-18-2006 07:35 PM
Our 58 Sovereign of the Road robandzoe Repairing/Replacing Floor &/or Frame 16 01-28-2006 04:41 PM
Forum Software Upgrade... Andy R Our Community 214 05-06-2004 10:55 AM
