04-15-2020, 08:10 PM
#221
1966 22' Safari
1954 22' Flying Cloud
Saline
, Michigan
First top done- second later Attachment 365821Attachment 365821
So fast forward and the first of two tops are done
04-16-2020, 07:37 AM
#222
On adventure with H&G
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Originally Posted by goshawks00
That is fantastic looking! Just impressive as anything, am filing that idea away for adaption later on.
--Matt
Too many trailers, not enough time.
04-21-2020, 09:54 PM
#223
1966 22' Safari
Saline
, Michigan
Originally Posted by Bubba L
It’s the punch list items at the end of a rebuild that seems to take the longest time. I still haven’t completely figured out the shower pan so that’s not finished.
We cancelled a couple of trips here in Texas as the result of park closures. We have reservations at the vintage rally at Pismo Beach in May, but I’m sure that’ll be cancelled as well. We’re hanging here at home taking care of projects like painting the fence posts and gates, cutting cedar, putting together another bat house, working on a stained glass project, etc. There’s plenty to keep us busy and away from town. Take care
Just finished making and planting 5 new bluebird houses.
04-21-2020, 10:02 PM
#224
1966 22' Safari
Saline
, Michigan
Just finished up making and planting five new bluebird boxes
04-22-2020, 06:21 AM
#225
1966 22' Safari
Fredericksburg
Barry, great on the Bluebird houses. We had made some for our west fence line when we got into Wildlife management a couple decades ago. We get the Eastern Bluebird. We get a few migratory but some have decided to move here permanently. I like your pole mount much better than the fence post mount. Take care and be safe.
04-24-2020, 06:43 PM
#226
1966 22' Safari
Saline
, Michigan
A Cloud named 'Spoon'
So have had several pairs of bluebirds -shopping-, but no committals yet. Today I put the window eye brows on, all but one as I ran out out Olympics, am four short. Ordered 100 today so will be down for a little while. Excited to try out a friends Buff Pro polisher. I bought new drums and some nuvite so we will starting polishing when it’s a little warmer.
While at it I added a new shelf up front, along with a dual 12v outlet. One a cigarette type, the other a dual phone charger port.
05-27-2020, 06:50 PM
#227
1966 22' Safari
Saline
, Michigan
Things are slowing down with the warmer weather,the check list is down to about twelve items, and I need to start polishing before it gets to warm. [ATTACH] This first cut of nuv. 7 is almost done.
07-01-2020, 10:37 AM
#228
1966 22' Safari
Saline
, Michigan
Finally able to add a couple of pics. The interior is about all done, and am still plugging away on polishing. There are only 17 tick marks to finish( if nothing gets added).
07-01-2020, 11:00 AM
#229
1966 22' Safari
Saline
, Michigan
[attach]
07-02-2020, 04:39 AM
#230
1956 22' Safari
1962 28' Ambassador
Williston
, Vermont
Gorgeous. Nicely done. I've saved your photos in my ideas folder and some may end up in my Ambassador. Thanks for posting - Mark
07-03-2020, 01:24 PM
#231
1966 22' Safari
Saline
, Michigan
Thanks Steve, there are multiple things we have tried to do differently on this build. It is always fun to try and think outside the box and learn new skills along the way. Thanks
08-03-2020, 06:59 AM
#232
1966 22' Safari
Saline
, Michigan
Still plugging away on Spoon , finishing a few things Polishing with C is about done need to do the bottom foot all the way wining installed around , then on to the cyclo-yay! Finished the trim on the wheel wells, sanding out the rear bumper before paint, and working on installing the Zipdee awning
OPPS bump in the road—-while traditionally the awning is a rope and stake affair, we chose to go modern here for easy of use and not be limited to where we can camp.
Couple of issues - first Steve Blackmer warned me about this- when he had his awning done at the Zipdee recommended size. When closed the awning arms prevent the side window from opening, knowing the I ordered my awning 2 1/2” longer. That will work. How ever the awning brackets now are 1-1/4” to far away from where they are attached to the rib/c channel per side. No problem I made a bracket plate to attach to the bracket which allowed me to then attach to the rib/c channel. That done it clears great - I’m happy, now we can open the windows. Problem 1 solved.
Once I put the arms on it be came evident I have Another problem-2
once the head is put on it be came apparent that the head is actually above the awning rail, and the upper bracket with the wheel on it is also above the awning rail. Today i call Zipdee to see what they have to say. Talking to couple of guys the consensus is that the awning rail needs to be moved up several inches. More to follow, here is a pic maybe you can see the dilemma.
08-03-2020, 09:39 AM
#233
1958 26' Overlander
Battle Ground
Instead of moving the awning rail can you shorten one/some of the arm components to lower the head or would that put the head too low when deployed?
I did that to get a better fit to the side profile of my 58 as the arms I bought were too long. A non-ferrous blade in a chop/miter saw works quite well. (My 58 is raised with a straight axle and over sized tires for ground clearance so it didn't compromise awning height.)
At the top I only had to drill 2 new holes; 1 to bolt on the spring arm and 1 to clear the 'axle' on the spring arm. The original is universal so it has elongated holes on both sides to clear the spring arm axle whether mounted at front or back.
08-03-2020, 09:41 PM
#234
1966 22' Safari
Saline
, Michigan
Attachment 374849 Attachment 374850
I’m not sure what type awning you have, but definitely not a Zipdee, maybe a Carefree? Will be doing a little research before committing to raising awning rail.
08-04-2020, 07:07 AM
#235
1978 25' Tradewind
1954 15' Byam Holiday
Linden
, Michigan
ZipDee?
Definetly looks like a Carefree to me. This is a whole different set-up.
08-05-2020, 12:26 PM
#236
1966 22' Safari
Saline
, Michigan
A little bit of modifying and reaching I was able to get the awning on w/o issue [ATTACH]
08-05-2020, 12:28 PM
#237
1966 22' Safari
Saline
, Michigan
now I can get back to polishing!
08-07-2020, 08:06 PM
#238
1966 22' Safari
Saline
, Michigan
awning done[ATTACH]
10-10-2020, 07:59 AM
#239
1966 22' Safari
Saline
, Michigan
a long summer with camping and life being busy, thought I’d a picture of our now finish ceiling lights. They are on a dimmer for full control[ATTACH]380443
01-07-2022, 01:45 PM
#240
1966 22' Safari
Saline
, Michigan
[QUOTE=goshawks00;2419872]a long summer with camping and life being busy, thought I’d a picture of our now finish ceiling lights. They are on a dimmer for full control
